path: root/board/cm5200
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-02-08Clean up libfdt.h includesGerald Van Baren
The libfdt.h file is the definition file for libfdt. It is unnecessary to include other fdt header files (the necessary ones are pulled in by libfdt.h). Signed-off-by: Gerald Van Baren <gvb@unssw.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12cm5200: Make function test command names more uniquePeter Tyser
Add "_test" to cm5200's function test command names to prevent overlap with common, global function names. Originally, the "do_i2c" function test command interfered with common/cmd_i2c.c's "do_i2c" when CONFIG_I2C_CMD_TREE was defined. The functions were also made static as they are not globally accessed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-09Some copy-n-paste fixes in printf usageMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-02-22Replace deprecated "ramdisk" with "ramdisk_size" kernel parameter.Detlev Zundel
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove final traces of long-deprecated "ramdisk" kernel parm") makes these changes neccessary. Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-12-07Convert boards that set memory node to use fdt_fixup_memory()Kumar Gala
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-05CM5200: Fix missing null-termination in hostname manipulation codeBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-13cm5200: Fix a typo introduced by afaac86fe2948ac84cd9a12bbed883b3c683e7d9Bartlomiej Sieka
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-03cm1_qp1 -> cm5200: single U-Boot image for modules from the cm5200 family.Bartlomiej Sieka
Add the ability for modules from the Schindler cm5200 family to use a single U-Boot image: - rename cm1_qp1 to cm5200 - add run-time module detection - parametrize SDRAM configuration according to the module we are running on Few minor, board-specific fixes included in this patch: - better MAC address handling - updated default environment ('update' command uses +{filesize} now) - improved error messages in the auto-update code - allow booting U-Boot from RAM (CFG_RAMBOOT) Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
