There was for long time no activity in the mpx5xxx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
Drop use of this long-deprecated option.
This option is pretty old. It predates CONFIG_SYS_I2C which is itself
deprecated in favour of driver model. Disable it for all boards.
Also drop I2C options which depend on this.
This allows us to use the same DRAM init function on all archs. Add a
dummy function for arc, which does not use DRAM init here.
[trini: Dummy function on nios2]
At present we cannot use this function as an init sequence call without a
wrapper, since it returns the RAM size. Adjust it to set the RAM size in
global_data instead, and return 0 on success.
It looks like only cm5200 and tqm8xx use this feature, so we don't really
need it in generic code. Drop it and have the users access gd->board_type
directly.
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT:
config OF_BOARD_SETUP
bool "Set up board-specific details in device tree before boot"
depends on OF_LIBFDT
remove superfluous tests of CONFIG_OF_LIBFDT when testing for
CONFIG_OF_BOARD_SETUP.
[trini: Typo fix: s/ifdefi/ifdef/]
This function is implemented by the legacy block functions now. Drop it.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
Remove FAT function prototypes from the cm5200 firmware update code, and
include the relevant headers instead.
This exposes the fact that the custom prototyoe for do_fat_read() in
this file was incorrect. Rather than simply fixing the call-site, replace
do_fat_read() with fat_exists(). This removes the only use of
do_fat_read() outside of the FAT code.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
This function can fail if the device tree runs out of space. Rather than
silently booting with an incomplete device tree, allow the failure to be
detected.
Unfortunately this involves changing a lot of places in the code. I have
not changed behvaiour to return an error where one is not currently
returned, to avoid unexpected breakage.
Eventually it would be nice to allow boards to register functions to be
called to update the device tree. This would avoid all the many functions
to do this. However it's not clear yet if this should be done using driver
model or with a linker list. This work is left for later.
Acked-by: Anatolij Gustschin <agust@denx.de>
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4
(patman: RunPipe() should not pipe stdout/stderr unless asked),
Patman spits lots of "Invalid MAINTAINERS address: '-'"
error messages for patches with global changes.
It takes too long for Patman to process them.
Anyway, "M: -" does not carry any important information.
Rather, it is just like a place holder in case of assigning
a new board maintainer. Let's comment out.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/'
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The libfdt.h file is the definition file for libfdt. It is unnecessary
to include other fdt header files (the necessary ones are pulled in
by libfdt.h).
Signed-off-by: Gerald Van Baren <gvb@unssw.com>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Currently, some linker scripts are found by common code in config.mk.
Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is
sometimes in arch config.mk and sometimes in board config.mk. Some
are found using an arch-specific rule for looking in CPUDIR, etc.
Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL
when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact
that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds.
Replace all of this -- except for a handful of boards that are actually
selecting a linker script in a unique way -- with centralized ldscript
finding.
If board code specifies LDSCRIPT, that will be used.
Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used.
If neither of these are specified, then the central config.mk will
check for the existence of the following, in order:
$(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT)
$(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT)
$(TOPDIR)/board/$(BOARDDIR)/u-boot.lds
$(TOPDIR)/$(CPUDIR)/u-boot.lds
Some boards (sc3, cm5200, munices) provided their own u-boot.lds that
were dead code, because they were overridden by a CPUDIR u-boot.lds under
the old powerpc rules. These boards' own u-boot.lds have bitrotted and
no longer work -- these lds files have been removed.
Tested-by: Graeme Russ <graeme.russ@gmail.com>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
The duplication of the do_bootm prototype has gotten out of hand,
and they're pretty much all outdated (wrt constness). Unify them
all in command.h.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
After the recent cleanups, a number of config.mk files consist only of
a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed.
Remove such entries. In most cases, that means that the whole
config.mk file can be removed.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
This patch introduces a weak default function for post_hotkey_pressed(),
returning 0, for boards without hotkey support. The long-running tests
won't be started on those boards. This default function was implemented
in many board directories. By implementing this weak default we can
remove all those duplicate versions.
Boards with hotkey support, can override this weak default function
by defining one in their board specific code.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Add "_test" to cm5200's function test command names to prevent
overlap with common, global function names. Originally, the
"do_i2c" function test command interfered with
common/cmd_i2c.c's "do_i2c" when CONFIG_I2C_CMD_TREE was defined.
The functions were also made static as they are not globally accessed.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove
final traces of long-deprecated "ramdisk" kernel parm") makes these
changes neccessary.
Signed-off-by: Detlev Zundel <dzu@denx.de>
