Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove
final traces of long-deprecated "ramdisk" kernel parm") makes these
changes neccessary.
Signed-off-by: Detlev Zundel <dzu@denx.de>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from
the device tree compiler (dtc) project.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Add the ability for modules from the Schindler cm5200 family to use a
single U-Boot image:
- rename cm1_qp1 to cm5200
- add run-time module detection
- parametrize SDRAM configuration according to the module we are running on
Few minor, board-specific fixes included in this patch:
- better MAC address handling
- updated default environment ('update' command uses +{filesize} now)
- improved error messages in the auto-update code
- allow booting U-Boot from RAM (CFG_RAMBOOT)
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com>
