path: root/board/cm5200
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-09Some copy-n-paste fixes in printf usageMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-02-22Replace deprecated "ramdisk" with "ramdisk_size" kernel parameter.Detlev Zundel
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove final traces of long-deprecated "ramdisk" kernel parm") makes these changes neccessary. Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-12-07Convert boards that set memory node to use fdt_fixup_memory()Kumar Gala
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-05CM5200: Fix missing null-termination in hostname manipulation codeBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-13cm5200: Fix a typo introduced by afaac86fe2948ac84cd9a12bbed883b3c683e7d9Bartlomiej Sieka
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-03cm1_qp1 -> cm5200: single U-Boot image for modules from the cm5200 family.Bartlomiej Sieka
Add the ability for modules from the Schindler cm5200 family to use a single U-Boot image: - rename cm1_qp1 to cm5200 - add run-time module detection - parametrize SDRAM configuration according to the module we are running on Few minor, board-specific fixes included in this patch: - better MAC address handling - updated default environment ('update' command uses +{filesize} now) - improved error messages in the auto-update code - allow booting U-Boot from RAM (CFG_RAMBOOT) Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
