path: root/board/cm41xx
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-15arm: Use sections header to obtain link symbolsSimon Glass
Include this header to get access to link symbols, which are otherwise removed. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-16board/cm41xx/flash.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: flash.c: In function 'flash_erase': flash.c:209:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:373:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM41xx: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm41xx.c: In function ‘env_flash_cmdline’: cm41xx.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4000: fix broken flash base for OpenGear boardsGreg Ungerer
Use _bss_start_ofs as the size of the boot loader code+data that we want to protect in the flash. This replaces use of the no longer defined _armboot_start. Fixes: flash.c: In function ‘flash_init’: flash.c:75: error: ‘_bss_start’ undeclared (first use in this function) flash.c:75: error: (Each undeclared identifier is reported only once flash.c:75: error: for each function it appears in.) flash.c:75: error: ‘_armboot_start’ undeclared (first use in this function) Signed-off-by: <greg.ungerer@opengear.com>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
