path: root/board/cm-bf548
2011-06-03Blackfin: boards: build zlib dir with -O2Mike Frysinger
Now that the zlib code has been relocated to a dedicated subdir, make sure we still build it with -O2 for boards that want speed over size. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cm-bf548: video: convert from old style MMR macrosMike Frysinger
The old MMR defines are being scrubbed, so convert the driver to use the new standard helper macros. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-11Blackfin: shutdown video DMA when booting LinuxMichael Hennerich
In case there is no frame buffer driver present in Linux to hand over the PPI LCD DMA upon boot, the DMA initiated by u-boot to display the splash screen runs unattended. Therefore always stop the video driver in u-boot before starting Linux. If people don't want this behavior, then they can simply stub out the video_stop() function in their board video driver. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: cm-bf548: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-09-02Blackfin: cm-bf548: fix device->stdio_dev falloutMike Frysinger
The recent 52cb4d4fb348 commit which renamed device to stdio_dev missed the cm-bf548's video board. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: enable -O2 in lib_generic/ for ADI/Bluetechnix boardsMike Frysinger
Building the compression code in lib_generic/ with -O2 rather than -Os gives a nice speed boost without too much code size increase. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: cm-bf548: new board portMike Frysinger
