path: root/board/cm-bf527/gpio.c
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: cm-bf527: new board portMike Frysinger
