path: root/board/cloudengines
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-07-07kirkwood: fix calls to kirkwood_mpp_confValentin Longchamp
With the new second save argument introduced by the previous patch, all the calls to the function had to be fixed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-05-15kirkwood: add support for Cloud Engines Pogoplug E02David Purdy
This patch adds support for Cloud Engines Pogoplug E02 Information regarding the CE Pogoplug E02 board can be found at: http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray Signed-off-by: Dave Purdy <david.c.purdy@gmail.com> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
