When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Additionally the SDRAM address decoding register address is not hard coded
in the C code any more. A define is introduced for this base address.
This makes is possible to use those gpio functions from other MVEBU SoC's
as well.
Tested-by: Luka Perkov <luka@openwrt.org>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
This makes is possible to use those gpio functions from other MVEBU SoC's as well.
This move makes is possible to use this header not only from kirkwood
platforms but from all Marvell mvebu platforms.
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
Many boot image configuration files refer to the
appropriate documentation file, but these references
contain typos in the directory and file name. Fix
them. Also fix reference to doc/README.SPL file.
This saves stack and code memory for local copy, and
consumes initialized data memory. For 22 of the 29
kirkwood-based boards, this results in a global saving
of about 30 bytes. For 7 of them, it results in an
increase of 6 to 14 bytes.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
With the new second save argument introduced by the previous patch, all
the calls to the function had to be fixed.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
This patch adds support for Cloud Engines Pogoplug E02
Information regarding the CE Pogoplug E02 board can be found at:
http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray
Signed-off-by: Dave Purdy <david.c.purdy@gmail.com>
Cc: prafulla@marvell.com
Cc: albert.u.boot@aribaud.net
