path: root/board/chromebook-x86
2014-11-21x86: Rename chromebook-x86 to corebootSimon Glass
Rename this vendor since it is intended to be used on any platform where coreboot runs at reset and then loads U-Boot. So far it is only tested on link. When other boards are supported it is likely that we will need to move to multiple board names, all under the 'coreboot' vendor. So while it would be possible to remove the vendor for now, that would be short-sighted. Suggested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22x86: cros_ec: Enable cros_ec for linkSimon Glass
Add defines to enable the Chrome OS EC interface and set it up on init. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-24x86: coreboot: delete unused coreboot/config.mkMasahiro Yamada
HOSTCFLAGS_autoconf.mk.dep was added by commit 422322f but it has never been used. Cc: Vadim Bendebury <vbendeb@chromium.org> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-01x86: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-02dt: don't use ARCH_CPU_DTSStephen Warren
Now that we assume dtc supports the -i option, we don't need to use ARCH_CPU_DTS in *.dts{,i}; we simply specify the include filename directly, and dtc will find it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-03-19x86: Add FDT SPI node for linkSimon Glass
Add a memory-mapped 8GB SPI chip. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04x86: Adjust link device tree include fileSimon Glass
This is currently set to coreboot.dtsi, but we cannot support this on old device tree compilers (dtc <= 1.3), so adjust to use ARCH_CPU_DTS to let the Makefile preprocessor sort this out. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-06x86: fdt: Create basic .dtsi file for corebootSimon Glass
This contains just the minimum information for a coreboot-based board. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: Add a minimal device tree for alex x86Gabe Black
The device tree now includes the necessary console configuration information. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: Remove coreboot start16 codeSimon Glass
This file is no longer needed for coreboot. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-28x86: Remove coreboot start16 codeSimon Glass
Now that coreboot doesn't need the start16 code, remove it. We need to remove the CONFIG_SYS_X86_RESET_VECTOR option from coreboot.h also. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-28x86: coreboot: Modify u-boot code to allow building coreboot payloadVadim Bendebury
This prevents the preprocessor from complaining when processing variadic macros Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2012-11-28x86: coreboot: Move non-board specific files to coreboot arch directoryStefan Reinauer
coreboot.c and coreboot_pci.c don't contain board specific but only coreboot specific code. Hence move it to the coreboot directory in arch/x86/cpu (which should probably be moved out of cpu/ in another commit) Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-19x86: Import code from coreboot's libpayload to parse the coreboot tableGabe Black
This change also forces the lib_sysinfo structure to be in the .data section. Otherwise it ends up in the .bss section. U-boot assumes that it doesn't need to copy it over during relocation, and instead fills that whole section with zeroes. If we really were booting from ROM that would be appropriate, but we need some information from the coreboot tables (memory size) before then and have to fill that structure before relocation. We skirt u-boot's assumption by putting this in .data where it assumes there is still read only but non-zero data. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
