path: root/board/chipspark
2017-01-11rockchip: board: popmetal: de-assert the host rst pin in board initKever Yang
The PopMetal board have a on board FE1.1 usb 2.0 hub which connect to the usb host port, we need to de-assert its reset pin to enable it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Added rockchip: tag: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: add support for rk3288 PopMetal boardjk.kernel@gmail.com
PopMetal is a rockchip rk3288 based board made by ChipSpark, which has many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and Gigabit Ethernet. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
