path: root/board/cerf250
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-10-22PXA: cerf250: Fix for relocMarek Vasut
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-07-10* Patch by Prakash Kumar, 27 Jun 2004:wdenk
Add support for the PXA250 based Intrinsyc Cerf board. * Patch by Yasushi Shoji, 27 Jun 2004: fix comment in include/common.h
