2006-10-09 | Move "ar" flags to config.mk to allow for silent "make -s" | Wolfgang Denk | |
Based on patch by Mike Frysinger, 20 Jun 2006 | |||
2006-09-01 | Add support for a saving build objects in a separate directory. | Marian Balakowicz | |
Modifications are based on the linux kernel approach and support two use cases: 1) Add O= to the make command line 'make O=/tmp/build all' 2) Set environement variable BUILD_DIR to point to the desired location 'export BUILD_DIR=/tmp/build' 'make' The second approach can also be used with a MAKEALL script 'export BUILD_DIR=/tmp/build' './MAKEALL' Command line 'O=' setting overrides BUILD_DIR environent variable. When none of the above methods is used the local build is performed and the object files are placed in the source directory. | |||
2005-07-25 | * Patch by Jon Loeliger, 2005-05-05 | Jon Loeliger | |
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O |
