path: root/board/ccv
2017-10-12i.mx6ul: xpress: update UART init for current board revisionAnatolij Gustschin
UART pinmux has been changed on the last board revision. Change board pinmux accordingly. Console is on UART7 now, add pinmux, base address and update console string in environment. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-04-13xpress: Update <usb/ehci-fsl.h> includeTom Rini
This has been renamed to <usb/ehci-ci.h> some time ago but was missed here. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-26arm: mx6: Add CCV xPress board supportStefan Roese
This patch add support for the CCV xPress board which is equipped with the i.MX6UL. And provides the following interfaces: - 128MiB DDR - UART - I2C - eMMC (with booting) - Ethernet - USB This patch adds two build targets. One with and one without SPL. The non-SPL version is used for loading U-Boot via USB (imx_usb_loader). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
