path: root/board/calao
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-12-09arm: at91: support for the Calao USB-A9263 board (based on AT91SAM9263)Mateusz Kulikowski
Add support for USB-A9263 board manufactured by Calao Systems (http://www.calao-systems.com/). Code is based on old U-Boot sources (2010.09) released by Calao. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm926ejs, at91: add common phy_reset functionHeiko Schocher
add common phy reset code into a common function. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Jens Scharsig <esw@bus-elektronik.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Stelian Pop <stelian@popies.net> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Eric Benard <eric@eukrea.com> Cc: Markus Hubig <mhubig@imko.de> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm:at91-boards: remove console_init_f where unnecessaryAndreas Bießmann
A lot of at91 boards have the console_init_f in board_init. This is useless cause it was called before by generic code in lib/board.c. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Jens Scharsig <esw@bus-elektronik.de> cc: Stelian Pop <stelian@popies.net> cc: Sedji Gaouaou<sedji.gaouaou@atmel.com> cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> cc: Eric Benard <eric@eukrea.com> Tested-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2011-12-19ARM: tny_a9260: re-add MACH_TYPE_TNY_A9G20 and MACH_TYPE_TNY_A9260Anatolij Gustschin
MACH_TYPE_TNY_A9G20 and MACH_TYPE_TNY_A9260 were removed from mach-types.h. Add them to the board config file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-19ARM: sbc35_a9g20: re-add MACH_TYPE_SBC35_A9G20Anatolij Gustschin
MACH_TYPE_SBC35_A9G20 was removed from mach-types.h. Add it to the board config file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-03tny_a9260/tny_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> CC: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-09-03sbc35_a9g20: update board to the new AT91 organizationThomas Petazzoni
Cc: Albin Tonnerre <tonnerrealbin@gmail.com> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de> Removed SBC35 from MAKEALL
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-01Support for the Calao TNY-A9260/TNY-A9G20 boardsAlbin Tonnerre
The Calao TNY-A9260 and TNY-9G20 are boards manufactured and sold by Calao Systems <http://www.calao-systems.com>. Their components are very similar to the AT91SAM9260EK board, so their configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, no ethernet. They also can use SPI EEPROM to store the environment. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-09-01Add support for the Calao SBC35-A9G20 boardAlbin Tonnerre
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems <http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. More informations can be found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
