path: root/board/broadcom
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-20board: ns2: Add support for Broadcom Northstar 2Jon Mason
Add support for the Broadcom Northstar2 SoC and SVK (bcm958712k). The BCM5871X is a series of quad-core 64-bit 2GHz ARMv8 Cortex-A57 processors targeting a broad range of networking applications. Signed-off-by: Jon Mason <jon.mason@broadcom.com>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-06-27maintainers: new email addressSteve Rae
Update the email address for the boards that I maintain. Signed-off-by: Steve Rae <steve.rae@raedomain.com>
2016-06-13board: arm:: Add support for Broadcom BCM23550Steve Rae
Add support for the Broadcom BCM23550 board. Signed-off-by: Steve Rae <srae@broadcom.com>
2015-12-17usb: s3c-otg: Rename usb/s3c_udc.h to usb/dwc2_udc.hMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch renames the global s3c_udc.h header to dwc2_udc.h. The rename is done automatically: $ sed -i "s/s3c_udc\.h/dwc2_udc.h/g" \ `git grep "s3c_udc\.h" | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename s3c_udc_probe() functionMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the second and final to rename global symbol, the s3c_udc_probe() function. The rename is done automatically: $ sed -i "s/s3c_udc_probe/dwc2_udc_probe/g" \ `git grep s3c_udc_probe | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename struct s3c_plat_otg_dataMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the first to rename global symbol, the struct s3c_plat_otg_data. The rename is done automatically: $ sed -i "s/s3c_plat_otg_data/dwc2_plat_otg_data/g" \ `git grep s3c_plat_otg_data | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-12arm: bcmcygnus: Enable Ethernet supportJiandong Zheng
Enable BCM SF2 ethernet and PHY for BCM Cygnus SoC Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-07-22implement Fastboot via USB OTG on bcm28155_ap boardsJiandong Zheng
2015-05-13ARM: Clean up CONFIG_ARMV7_NONSEC/VIRT/PSCI conditionsJan Kiszka
CONFIG_ARMV7_VIRT depends on CONFIG_ARMV7_NONSEC, thus doesn't need to be taken into account additionally. CONFIG_ARMV7_PSCI is only set on boards that support CONFIG_ARMV7_NONSEC, and it only works on those. CC: Tang Yuantian <Yuantian.Tang@freescale.com> CC: York Sun <yorksun@freescale.com> CC: Steve Rae <srae@broadcom.com> CC: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Tested-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-11-23ARM: bcm: Enable bcm11130 boardsSteve Rae
bcm11130 bcm11130_nand Signed-off-by: Steve Rae <srae@broadcom.com>
2014-11-23ARM: bcm: Enable five Cygnus boardsSteve Rae
bcm911360_entphn bcm911360_entphn-ns bcm911360k bcm958300k-ns bcm958305k - updates to support Cygnus and NSP board families better - add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards Signed-off-by: Steve Rae <srae@broadcom.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30arm: convert Cygnus and NSP boards to KconfigSteve Rae
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: add Cygnus and NSP boardsScott Branden
The bcm_ep board configuration is used by a number of boards including Cygnus and NSP. Add builds for the bcm958300k and the bcm958622hr boards. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: bcm281xx: add board with Ethernet capabilitySteve Rae
Add board which has Broadcom StarFighter2 Ethernet capability. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-04-17kbuild: do not use $(BOARD) to specify exact object nameMasahiro Yamada
2014-02-22board: bcm28155_ap: Add board filesDarwin Rambo
Add support for the bcm28155_ap reference board. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Tim Kryger <tkryger@linaro.org>
