path: root/board/boundary
2014-09-24spi: mxc: fix sf probe when using mxc_spiNikita Kiryanov
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high across multiple transactions. This is set up by embedding the GPIO information in the CS value: cs = (cs | gpio << 8) This merge of cs and gpio data into one value breaks the sf probe command: if the use of gpio is required, invoking "sf probe <cs>" will not work, because the CS argument doesn't have the GPIO information in it. Instead, the user must use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must type "sf probe 15872". This is inconsistent with the description of the sf probe command, and forces the user to be aware of implementaiton details. Fix this by introducing a new board function: board_spi_cs_gpio(), which will accept a naked CS value, and provide the driver with the relevant GPIO, if one is necessary. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-07-23mx6: Remove duplication of iomuxc structureFabio Estevam
There is no need to keep iomuxc_base_regs structure as it serves the exact same purpose of the iomuxc structure, which is to provide access to the GPR registers. The additional fields of iomuxc_base_regs are not used. Other advantage of 'iomuxc' is that it has a shorter name and the variable declarations can fit into a single line. So remove iomuxc_base_regs structure and use iomuxc instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-04-28nitrogen6x: Fix the PAD settings for the ECSPI chipselectFabio Estevam
ECSPI chipselect (MX6_PAD_EIM_D19__GPIO3_IO19) is used with GPIO functionality, so it does not make sense to set its pad as SPI pin. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-04-15nitrogen6x: use common detect_hdmiEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2014-04-15nitrogen6x: use common board_video_skipEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-02-19Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-19i.MX6: nitrogen6x: pedantic: BOOT_FROM==spi, not sdEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-02-06usb: mv_udc: Rename to ci_udcMarek Vasut
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Stefano Babic <sbabic@denx.de>
2014-01-26nitrogen6x: README: Do not refer to MAINTAINERS fileFabio Estevam
MAINTAINERS file has been removed from the project. Replace its reference with 'boards.cfg' file instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-01-26nitrogen6x: README: Only calling 'make' is enoughFabio Estevam
No need to pass 'u-boot.imx' as parameter for 'make' because u-boot.imx is built by default. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-12-17nitrogen6x: Move setup_sata to common partGiuseppe Pagano
Move setup_sata function definition from platform file nitrogen6x.c to arch/arm/imx-common/sata.c to avoid code duplication. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Eric Nelson <eric.nelson@boundarydevices.com>
2013-11-13i.MX6DQ/DLS: replace pad names with their Linux kernel equivalentsEric Nelson
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-10-31i.MX6: nitrogen6x: fix erase size in 6x_upgrade.txtEric Nelson
The 6x_upgrade script is used to upgrade U-Boot in SPI-NOR on Nitrogen6x/SABRE Lite boards using U-Boot's 'sf' command. U-Boot is placed at offset 0x400 in flash, and the script currently only erases 0x50000 bytes. Since the current head is 319k, any additional features enabled in the configuration will exceed the space erased and cause errors re-programming the device. This patch increases the erase size to the full size of the region allocated for the U-Boot binary. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-10-20nitrogen6x: add otg usb host/device mode supportTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20mx6: iomux: add GPR1 defines for use with nitrogen6xTroy Kisky
Select GPIO1 as the USB OTG ID pin for Nitrogen6x Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-10imx: nitrogen6x/mx6qsabrelite: Fix bug in board_video_skipRobert Winkler
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
2013-08-31i.MX6: nitrogen6x: Don't bother setting PLL3(480) PFD1 divisorEric Nelson
This clock isn't feeding anything under U-Boot, so there's no point in changing it from power-on default. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-08-21i.MX6: nitrogen6x: force HDMI onto IPU0/DI0Eric Nelson
Our Linux kernel switches the HDMI connector onto IPU0/DI1, but the U-Boot display driver only supports IPU0/DI0 for the time being. Because of this, a soft re-boot will leave the HDMI output connected to the wrong display port and prevent video from being displayed. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27imx: nitrogen6x: mx6qsabrelite: Add support for DVI monitorsRobert Winkler
A little background is probably appropriate for this patch. Since "the beginning" of usage of the SABRE Lite and Nitrogen6x boards, DVI detection has been somewhat broken. Some (most) DVI monitors don't produce the "HPD" bit in the PHY_STAT0 register, but do show proper toggling of the RX_SENSE0..3 bits. Creating a new the bit-mask to include all five bits and modifying the 'hdmidet' command and internal detection routines allows these monitors to function properly in U-Boot. A related patch to our kernels allows things to work under Linux: https://github.com/boundarydevices/linux-imx6/commit/7d8752905c118af9063738a533227de0b2f6ecd4 Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6: Factor out common HDMI setup codePardeep Kumar Singla
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com> Acked-By: Eric Nelson <eric.nelson@boundarydevices.com>
2013-07-26mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6xFabio Estevam
mx6qsabrelite and nitrogen6q boards are hardware compatible, so let's avoid the code duplication and only use the nitrogen6x source code to make board code maintainance easier. Tested booting a mainline device tree kernel on a mx6qsabrelite board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-20ddr cfg: DRAM_RESET needs 0x00020030Troy Kisky
The old value of 0x000e0030 will cause ethernet timeout issues on the sabrelite and possibly other boards using the KSZ9021. I have no explanation as to why. But this is a correct change, the TRM will be updated to show that 00b is the only valid setting for bits 19-18 of DRAM_RESET. My thanks go to Liu Hui(Jason) for this information. Acked-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-06-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/Makefile
2013-06-03mx6: mx6qsabrelite/nitrogen6x: Remove incorrect setting of gpio CS signalAndrew Gabbasov
The number of gpio signal is packed inside CONFIG_SF_DEFAULT_CS macro (shifted and or'ed with chip select), so it's incorrect to pass that macro directly as an argument to gpio_direction_output() call. Also, SPI driver sets the direction and initial value of a gpio, used as a chip select signal, before any actual activity happens on the bus. So, it is safe to just remove the gpio_direction_output call, that works incorrectly, thus making no effect, anyway. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Tested-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-28imx: iomux-v3: Include PKE and PUE to pad control pull definitionsBenoît Thébaudeau
PUE requires PKE to mean something, as do pull values with PUE, so do not compell users to explicitly use PKE and PUE everywhere. This is also what is done on Linux and what has already been done for i.MX51. By the way, remove some unused pad control definitions. There is no change of behavior. Note that SPI_PAD_CTRL was defined by several boards with a pull value, but without PKE or PUE, which means that no pull was actually enabled in the pad. This might be a bug in those boards, but this patch does not change the behavior, so it just removes the meaningless pull value from those definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-25nitrogen6x: Setup CCM_CCOSR registerFabio Estevam
CKO1 drives sgtl5000 codec clock on nitrogen boards and wandboard. Doing this setup in the bootloader will allow us to remove a lot of code in arch/arm/mach-imx/mach-imx6q.c from the mainline kernel. Also, according to Eric Nelson: "enabling the clock <in the bootloader> will remove squeal after an ungraceful reboot (watchdog) if hooked up to speakers." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-03mx6: Fix get_board_rev() for the mx6 solo caseFabio Estevam
When booting a Freescale kernel 3.0.35 on a Wandboard solo, the get_board_rev() returns 0x62xxx, which is not a value understood by the VPU (Video Processing Unit) library in the kernel and causes the video playback to fail. The expected values for get_board_rev are: 0x63xxx: For mx6quad/dual 0x61xxx: For mx6dual-lite/solo So adjust get_board_rev() accordingly and make it as weak function, so that we do not need to define it in every mx6 board file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-04-03mmc: i.MX6: fsl_esdhc: Define maximum bus width supported by a boardAbbas Raza
Maximum bus width supported by some i.MX6 boards is not 8bit like others. In case where both host controller and card support 8bit transfers, they agree to communicate on 8bit interface while some boards support only 4bit interface. Due to this reason the mmc 8bit default mode fails on these boards. To rectify this, define maximum bus width supported by these boards (4bit). If max_bus_width is not defined, it is 0 by default and 8bit width support will be enabled in host capabilities otherwise host capabilities are modified accordingly. It is tested with a MMCplus card. Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com> cc: stefano Babic <sbabic@denx.de> cc: Andy Fleming <afleming@gmail.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2013-03-15nitrogen: Use unsigned long to specify the total RAM sizefabio.estevam@freescale.com
When building for the nitrogen boards with 2GiB the following warning happens: nitrogen6x.c:89:38: warning: integer overflow in expression [-Woverflow] 2GiB can not fit in 32-bits, so use ulong instead. Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
