path: root/board/boundary
2013-07-20ddr cfg: DRAM_RESET needs 0x00020030Troy Kisky
The old value of 0x000e0030 will cause ethernet timeout issues on the sabrelite and possibly other boards using the KSZ9021. I have no explanation as to why. But this is a correct change, the TRM will be updated to show that 00b is the only valid setting for bits 19-18 of DRAM_RESET. My thanks go to Liu Hui(Jason) for this information. Acked-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-06-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/Makefile
2013-06-03mx6: mx6qsabrelite/nitrogen6x: Remove incorrect setting of gpio CS signalAndrew Gabbasov
The number of gpio signal is packed inside CONFIG_SF_DEFAULT_CS macro (shifted and or'ed with chip select), so it's incorrect to pass that macro directly as an argument to gpio_direction_output() call. Also, SPI driver sets the direction and initial value of a gpio, used as a chip select signal, before any actual activity happens on the bus. So, it is safe to just remove the gpio_direction_output call, that works incorrectly, thus making no effect, anyway. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Tested-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-28imx: iomux-v3: Include PKE and PUE to pad control pull definitionsBenoît Thébaudeau
PUE requires PKE to mean something, as do pull values with PUE, so do not compell users to explicitly use PKE and PUE everywhere. This is also what is done on Linux and what has already been done for i.MX51. By the way, remove some unused pad control definitions. There is no change of behavior. Note that SPI_PAD_CTRL was defined by several boards with a pull value, but without PKE or PUE, which means that no pull was actually enabled in the pad. This might be a bug in those boards, but this patch does not change the behavior, so it just removes the meaningless pull value from those definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-25nitrogen6x: Setup CCM_CCOSR registerFabio Estevam
CKO1 drives sgtl5000 codec clock on nitrogen boards and wandboard. Doing this setup in the bootloader will allow us to remove a lot of code in arch/arm/mach-imx/mach-imx6q.c from the mainline kernel. Also, according to Eric Nelson: "enabling the clock <in the bootloader> will remove squeal after an ungraceful reboot (watchdog) if hooked up to speakers." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-03mx6: Fix get_board_rev() for the mx6 solo caseFabio Estevam
When booting a Freescale kernel 3.0.35 on a Wandboard solo, the get_board_rev() returns 0x62xxx, which is not a value understood by the VPU (Video Processing Unit) library in the kernel and causes the video playback to fail. The expected values for get_board_rev are: 0x63xxx: For mx6quad/dual 0x61xxx: For mx6dual-lite/solo So adjust get_board_rev() accordingly and make it as weak function, so that we do not need to define it in every mx6 board file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-04-03mmc: i.MX6: fsl_esdhc: Define maximum bus width supported by a boardAbbas Raza
Maximum bus width supported by some i.MX6 boards is not 8bit like others. In case where both host controller and card support 8bit transfers, they agree to communicate on 8bit interface while some boards support only 4bit interface. Due to this reason the mmc 8bit default mode fails on these boards. To rectify this, define maximum bus width supported by these boards (4bit). If max_bus_width is not defined, it is 0 by default and 8bit width support will be enabled in host capabilities otherwise host capabilities are modified accordingly. It is tested with a MMCplus card. Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com> cc: stefano Babic <sbabic@denx.de> cc: Andy Fleming <afleming@gmail.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2013-03-15nitrogen: Use unsigned long to specify the total RAM sizefabio.estevam@freescale.com
When building for the nitrogen boards with 2GiB the following warning happens: nitrogen6x.c:89:38: warning: integer overflow in expression [-Woverflow] 2GiB can not fit in 32-bits, so use ulong instead. Reported-by: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
