path: root/board/boundary
2022-11-21Fix usage of CONFIG_PREBOOTPali Rohár
Due to usage of PREBOOT in Kconfig, macro CONFIG_PREBOOT is always defined when CONFIG_USE_PREBOOT is enabled. In case CONFIG_PREBOOT is not explicitly enabled it is set to empty C string and therefore '#ifdef CONFIG_PREBOOT' guard does not work. Fix this issue by introducing a new Kconfig symbol PREBOOT_DEFINED which cause to define new C macro CONFIG_PREBOOT_DEFINED only when CONFIG_PREBOOT is really defined. Change usage of '#ifdef CONFIG_PREBOOT' by '#ifdef CONFIG_USE_PREBOOT' for code which checks if preboot code would be called and by '#ifdef CONFIG_PREBOOT_DEFINED' for defining preboot code. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-04-10net: phy: don't require PHY interface mode during PHY creationMarek Behún
Currently we require PHY interface mode to be known when finding/creating the PHY - the functions * phy_connect_phy_id() * phy_device_create() * create_phy_by_mask() * search_for_existing_phy() * get_phy_device_by_mask() * phy_find_by_mask() all require the interface parameter, but the only thing done with it is that it is assigned to phydev->interface. This makes it impossible to find a PHY device without overwriting the set mode. Since the interface mode is not used during .probe() and should be used at first in .config(), drop the interface parameter from these functions. Make the default value of phydev->interface (in phy_device_create()) to be PHY_INTERFACE_MODE_NA. Move the interface parameter to phy_connect_dev(), where it should be. Change all occurrences treewide. In occurrences where we don't call phy_connect_dev() for some reason (they only configure the PHY without connecting it to an ethernet controller), set phydev->interface = value from phy_find_by_mask call. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Ramon Fried <rfried.dev@gmail.com> Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com>
2022-03-18imx: Convert some boards to DM_ETHTom Rini
A small number of i.MX6/7 and vf610 boards have not enabled DM_ETH yet. Given the state of the rest of the platform, enable DM_ETH. Cc: Alison Wang <alison.wang@nxp.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Richard Hu <richard.hu@technexion.com> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Uri Mashiach <uri.mashiach@compulab.co.il> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-02-08imx: Don't define __ASSEMBLY__ in source filesSimon Glass
This is supposed to be a build-system flag. Move it there so we can define it before linux/kconfig.h is included. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-09-30WS cleanup: remove SPACE(s) followed by TABWolfgang Denk
2021-09-30WS cleanup: remove trailing empty linesWolfgang Denk
2021-08-31nitrogen6x: Migrate DDR_MB to KconfigTom Rini
Move the CONFIG_DDR_MB symbol to Kconfig. A later clean-up would be to make dynamic memory size detection work based on how this is done on other i.MX6 platforms. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-06-25Merge tag 'xilinx-for-v2020.10' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.10 Versal: - xspi bootmode fix - Removing one clock from clk driver - Align u-boot memory setting with OS by default - Map TCM and OCM by default ZynqMP: - Minor DT improvements - Reduce console buffer for mini configurations - Add fix for AMS - Add support for XDP platform Zynq: - Support for AES engine - Enable bigger memory test by default - Extend documentation for SD preparation - Use different freq for Topic miami board mmc: - minor GD pointer removal net: - Support fixed-link cases by zynq gem - Fix phy looking loop in axi enet driver spi: - Cleanup global macros for xilinx spi drivers firmware: - Add support for pmufw reloading fpga: - Improve error status reporting common: - Remove 4kB addition space for FDT allocation
2020-06-22Fix MMC access on SabreliteMartyn Welch
It appears that MMC access on the Sabrelite has been broken since cdcaee9518: Loading Environment from MMC... Card did not respond to voltage select! *** Warning - No block device, using default environment Remove the board_mmc_init() and related entries now that we should be using DM_MMC, add PINCTRL so that things work as expected. Signed-off-by: Martyn Welch <martyn.welch@collabora.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Tested-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2020-06-18nitrogen6x: update video console nameAnatolij Gustschin
After migration to DM 'vga' name is not longer supported, Update the upgrade script to use 'vidconsole' instead. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16doc: update reference to README.imximagePatrick Delaunay
Update reference in many files detected by scripts/documentation-file-ref-check README.imximage => imx/mkimage/imximage.txt Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-12-27nitrogen6x: prepare for CONFIG_MX6QDLTroy Kisky
The next patch adds CONFIG_MX6QDL so that errata will be enabled again. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2019-10-08imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HABStefano Babic
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc. Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-10-08nitrogen6x: reserve used gpiosTroy Kisky
This prevents messages like gpio@20a0000: get_value: error: gpio GPIO2_2 not reserved when CONFIG_DM_GPIO is enabled. Also, when CONFIG_DM_GPIO is enabled, checkboard is too early to use gpio_get_value, so read it directly on failure. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2019-10-08nitrogen6x: migrate to using device treeTroy Kisky
Migrate to using device tree required for further driver model integration. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-03-13imx: mx6qsabrelite: Update the SabreLite READMEMartyn Welch
The information in the SabreLite README is inaccurate and sparse. The upstream U-Boot can boot the SabreLite from SPI-NOR. Additionally, the freely available imx_loader tool can be easily used to boot a board with a corrupted SPI, the official Freescale/NXP manufacturing tools are not required. Reformat the document, adding a description of how to boot from SPI-NOR and adding a brief description of how to recover the board should the SPI-NOR be corrupted using imx_loader. Signed-off-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-17nitrogen6x: add secure boot supportGary Bisson
Declaring a CSF section makes the imximage tool increase the size of data to be loaded by the BootROM and also adds a pointer to that CSF section in the IVT header to the BootROM can check the signature. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
2016-04-01usb: Rename ehci-fsl.h to ehci-ci.hMateusz Kulikowski
Most of ehci-fsl header describe USB controller designed by Chipidea and used by various SoC vendors. This patch renames it to a generic header: ehci-ci.h Contents of file are not changed (so it contains several references to freescale SoCs). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-13nitrogen6x: Fix the error handling in board_eth_init()Fabio Estevam
We should not return 0 on failure, so return a negative error code instead. Also centralize the error path so that is easier to follow. Cc: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02nitrogen6x: change maintainerEric Nelson
Troy Kisky will be maintaining the Nitrogen6x board going forward. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2015-02-17nitrogen6x: set environment variable reset_causeEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-24nitrogen6x: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-21ARM: i.MX: provide declaration for board_spi_cs_gpioEric Nelson
Provide a public declaration of the board_spi_cs_gpio() callback for i.MX SPI chip selects to prevent the warning "Should it be static?" when compiling with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-06nitrogen6x: display use I2C detect for HDMIEric Nelson
The HPD pin and RX_SENSE registers have proven to be less reliable than using I2C on the EDID pins for detection of an HDMI monitor. In particular, when the HDMI output is reset through a "reboot" cycle, the detect_hdmi() routine often bounces, resulting in a failure to detect a connected monitor. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add wvga-lvds panelEric Nelson
Add support for WVGA (800x480) panels using VESA GTF timings over LVDS. No auto-detection is supported, so you must configure this panel manually through the 'panel' environment variable: U-Boot > setenv panel svga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add Ampire 1024x600 panelEric Nelson
Add support for an Ampire 1024x600 LVDS panel with integrated Ilitek capacitive touch screen. Auto-detection is enabled, so no explicit configuration is needed. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add svga display (800x600)Eric Nelson
Add support for 800x600 18-bit RGB displays using VESA GTF timings. No auto-detection is supported, so you must configure this panel manually through the 'panel' environment variable: U-Boot > setenv panel svga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support for fusion 7 displayEric Nelson
Add support for the Touch Revolution Fusion7 display: 800x480 RGB with a custom F0710A resistive touch controller. Auto-detection of this panel is supported so no configuration is required. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add LDB-WXGA-S for SPWG 1280x800 displaysEric Nelson
This patch adds support for LVDS WXGA displays that use the SPWG encoding standard instead of JEIDA. No auto-detection is enabled and you must explicitly set the 'panel' environment variable: U-Boot > setenv panel LDB-WXGA-S U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support for LG-9.7 LVDS displayEric Nelson
Add support for LG 9.7" LVDS panel (1024x768) with integrated eGalax touch screen. Note that this panel differs only slightly from the Hannstar XGA panel (margins). No auto-detection is available because it shares the same touch controller as the Hannstar-XGA display, so you'll need to configure it through the 'panel' environment variable: U-Boot > setenv panel LG-9.7 U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add qvga panelEric Nelson
Add support for a 1/4 VGA panel with a 24-bit RGB interface. No auto-detection is enabled, so you must configure the 'panel' environment variable to use this display: U-Boot > setenv panel qvga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support lvds jeida screenRobert Winkler
Add support for Boundary Devices 7" and 10.1" 1280x800 displays with integrated FocalTech ft5x06 10-point touch controller. Because they share the touch controller with the 1024x600 displays, auto-detection is disabled and you must explicitly set the 'panel' environment variable: U-Boot > setenv panel LDB-WXGA U-Boot > saveenv && reset Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
