path: root/board/boundary/nitrogen6x/nitrogen6x.c
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-04-01usb: Rename ehci-fsl.h to ehci-ci.hMateusz Kulikowski
Most of ehci-fsl header describe USB controller designed by Chipidea and used by various SoC vendors. This patch renames it to a generic header: ehci-ci.h Contents of file are not changed (so it contains several references to freescale SoCs). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2015-09-13nitrogen6x: Fix the error handling in board_eth_init()Fabio Estevam
We should not return 0 on failure, so return a negative error code instead. Also centralize the error path so that is easier to follow. Cc: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
2015-02-17nitrogen6x: set environment variable reset_causeEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-24nitrogen6x: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-21ARM: i.MX: provide declaration for board_spi_cs_gpioEric Nelson
Provide a public declaration of the board_spi_cs_gpio() callback for i.MX SPI chip selects to prevent the warning "Should it be static?" when compiling with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-06nitrogen6x: display use I2C detect for HDMIEric Nelson
The HPD pin and RX_SENSE registers have proven to be less reliable than using I2C on the EDID pins for detection of an HDMI monitor. In particular, when the HDMI output is reset through a "reboot" cycle, the detect_hdmi() routine often bounces, resulting in a failure to detect a connected monitor. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add wvga-lvds panelEric Nelson
Add support for WVGA (800x480) panels using VESA GTF timings over LVDS. No auto-detection is supported, so you must configure this panel manually through the 'panel' environment variable: U-Boot > setenv panel svga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add Ampire 1024x600 panelEric Nelson
Add support for an Ampire 1024x600 LVDS panel with integrated Ilitek capacitive touch screen. Auto-detection is enabled, so no explicit configuration is needed. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add svga display (800x600)Eric Nelson
Add support for 800x600 18-bit RGB displays using VESA GTF timings. No auto-detection is supported, so you must configure this panel manually through the 'panel' environment variable: U-Boot > setenv panel svga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support for fusion 7 displayEric Nelson
Add support for the Touch Revolution Fusion7 display: 800x480 RGB with a custom F0710A resistive touch controller. Auto-detection of this panel is supported so no configuration is required. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add LDB-WXGA-S for SPWG 1280x800 displaysEric Nelson
This patch adds support for LVDS WXGA displays that use the SPWG encoding standard instead of JEIDA. No auto-detection is enabled and you must explicitly set the 'panel' environment variable: U-Boot > setenv panel LDB-WXGA-S U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support for LG-9.7 LVDS displayEric Nelson
Add support for LG 9.7" LVDS panel (1024x768) with integrated eGalax touch screen. Note that this panel differs only slightly from the Hannstar XGA panel (margins). No auto-detection is available because it shares the same touch controller as the Hannstar-XGA display, so you'll need to configure it through the 'panel' environment variable: U-Boot > setenv panel LG-9.7 U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add qvga panelEric Nelson
Add support for a 1/4 VGA panel with a 24-bit RGB interface. No auto-detection is enabled, so you must configure the 'panel' environment variable to use this display: U-Boot > setenv panel qvga U-Boot > saveenv && reset Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: display: add support lvds jeida screenRobert Winkler
Add support for Boundary Devices 7" and 10.1" 1280x800 displays with integrated FocalTech ft5x06 10-point touch controller. Because they share the touch controller with the 1024x600 displays, auto-detection is disabled and you must explicitly set the 'panel' environment variable: U-Boot > setenv panel LDB-WXGA U-Boot > saveenv && reset Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: prevent warnings about board_ehci* callbacksEric Nelson
Include declarations of board_ehci callbacks to prevent compiler warnings and enforce function prototypes. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: phy: add 100 us delay after phy resetTroy Kisky
Testing shows that the Micrel PHY may not be completely out of reset if accessed immediately. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: staticize board fileEric Nelson
Declare locally-used data structures and functions as static and pull in header files to prevent compiler warnings of "Should it be static?" when building with "make C=1". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: configure SGTL5000, CSI camera clock outputsTroy Kisky
Configure CLKO outputs for SGTL5000, CSI camera. The sys_mclk output for the SGTL500 in particular prevents Windows CE from properly driving audio. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: power-down miscellanous peripheralsEric Nelson
Ensure that cameras and USB OTG power are in a stable (reset) state at reset by configuring their pads and toggling GPIOs. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: configure SD2 pads for SDIO on USDHC2Eric Nelson
Pads SD2_CLK/CMD/DAT0-3 are connected to an SDIO WiFi device on Nitrogen and unconnected on BD-SL-i.MX6 (sabre lite). Configure them as SDIO pins to prevent them from being in a state that confuses the WiFi part. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06nitrogen6x: simplify board_mmc_getcdTroy Kisky
The same logic applies to both SD card slots, only with different GPIOs and the code should make that easier to see. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2014-10-06nitrogen6x: implement board_cfb_skip() to disable text outputEric Nelson
Several customers have asked to leave the display quiet during boot, so allow the user to express this request by the presence of environment variable "novideo". Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-09-24spi: mxc: fix sf probe when using mxc_spiNikita Kiryanov
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high across multiple transactions. This is set up by embedding the GPIO information in the CS value: cs = (cs | gpio << 8) This merge of cs and gpio data into one value breaks the sf probe command: if the use of gpio is required, invoking "sf probe <cs>" will not work, because the CS argument doesn't have the GPIO information in it. Instead, the user must use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must type "sf probe 15872". This is inconsistent with the description of the sf probe command, and forces the user to be aware of implementaiton details. Fix this by introducing a new board function: board_spi_cs_gpio(), which will accept a naked CS value, and provide the driver with the relevant GPIO, if one is necessary. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-07-23mx6: Remove duplication of iomuxc structureFabio Estevam
There is no need to keep iomuxc_base_regs structure as it serves the exact same purpose of the iomuxc structure, which is to provide access to the GPR registers. The additional fields of iomuxc_base_regs are not used. Other advantage of 'iomuxc' is that it has a shorter name and the variable declarations can fit into a single line. So remove iomuxc_base_regs structure and use iomuxc instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-04-28nitrogen6x: Fix the PAD settings for the ECSPI chipselectFabio Estevam
ECSPI chipselect (MX6_PAD_EIM_D19__GPIO3_IO19) is used with GPIO functionality, so it does not make sense to set its pad as SPI pin. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-04-15nitrogen6x: use common detect_hdmiEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2014-04-15nitrogen6x: use common board_video_skipEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-02-06usb: mv_udc: Rename to ci_udcMarek Vasut
The mv_udc is not marvell-specific anymore. The mv_udc is used to drive generic ChipIdea CI13xxx series OTG cores, so rename the driver to ci_udc instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Stefano Babic <sbabic@denx.de>
2013-12-17nitrogen6x: Move setup_sata to common partGiuseppe Pagano
Move setup_sata function definition from platform file nitrogen6x.c to arch/arm/imx-common/sata.c to avoid code duplication. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Eric Nelson <eric.nelson@boundarydevices.com>
2013-11-13i.MX6DQ/DLS: replace pad names with their Linux kernel equivalentsEric Nelson
2013-10-20nitrogen6x: add otg usb host/device mode supportTroy Kisky
2013-10-20mx6: iomux: add GPR1 defines for use with nitrogen6xTroy Kisky
Select GPIO1 as the USB OTG ID pin for Nitrogen6x Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-09-10imx: nitrogen6x/mx6qsabrelite: Fix bug in board_video_skipRobert Winkler
2013-08-31i.MX6: nitrogen6x: Don't bother setting PLL3(480) PFD1 divisorEric Nelson
This clock isn't feeding anything under U-Boot, so there's no point in changing it from power-on default. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-08-21i.MX6: nitrogen6x: force HDMI onto IPU0/DI0Eric Nelson
Our Linux kernel switches the HDMI connector onto IPU0/DI1, but the U-Boot display driver only supports IPU0/DI0 for the time being. Because of this, a soft re-boot will leave the HDMI output connected to the wrong display port and prevent video from being displayed. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27imx: nitrogen6x: mx6qsabrelite: Add support for DVI monitorsRobert Winkler
A little background is probably appropriate for this patch. Since "the beginning" of usage of the SABRE Lite and Nitrogen6x boards, DVI detection has been somewhat broken. Some (most) DVI monitors don't produce the "HPD" bit in the PHY_STAT0 register, but do show proper toggling of the RX_SENSE0..3 bits. Creating a new the bit-mask to include all five bits and modifying the 'hdmidet' command and internal detection routines allows these monitors to function properly in U-Boot. A related patch to our kernels allows things to work under Linux: https://github.com/boundarydevices/linux-imx6/commit/7d8752905c118af9063738a533227de0b2f6ecd4 Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6: Factor out common HDMI setup codePardeep Kumar Singla
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com> Acked-By: Eric Nelson <eric.nelson@boundarydevices.com>
2013-06-03mx6: mx6qsabrelite/nitrogen6x: Remove incorrect setting of gpio CS signalAndrew Gabbasov
The number of gpio signal is packed inside CONFIG_SF_DEFAULT_CS macro (shifted and or'ed with chip select), so it's incorrect to pass that macro directly as an argument to gpio_direction_output() call. Also, SPI driver sets the direction and initial value of a gpio, used as a chip select signal, before any actual activity happens on the bus. So, it is safe to just remove the gpio_direction_output call, that works incorrectly, thus making no effect, anyway. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Tested-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2013-04-28imx: iomux-v3: Include PKE and PUE to pad control pull definitionsBenoît Thébaudeau
PUE requires PKE to mean something, as do pull values with PUE, so do not compell users to explicitly use PKE and PUE everywhere. This is also what is done on Linux and what has already been done for i.MX51. By the way, remove some unused pad control definitions. There is no change of behavior. Note that SPI_PAD_CTRL was defined by several boards with a pull value, but without PKE or PUE, which means that no pull was actually enabled in the pad. This might be a bug in those boards, but this patch does not change the behavior, so it just removes the meaningless pull value from those definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
