path: root/board/boundary/nitrogen6x/clocks.cfg
2013-04-25nitrogen6x: Setup CCM_CCOSR registerFabio Estevam
CKO1 drives sgtl5000 codec clock on nitrogen boards and wandboard. Doing this setup in the bootloader will allow us to remove a lot of code in arch/arm/mach-imx/mach-imx6q.c from the mainline kernel. Also, according to Eric Nelson: "enabling the clock <in the bootloader> will remove squeal after an ungraceful reboot (watchdog) if hooked up to speakers." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-13Add Boundary Devices Nitrogen6X boardsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
