path: root/board/bosch
2019-04-12am335x, guardian: Add support for the bosch guardian boardSjoerd Simons
Add support for the Bosch Guardian board. CPU : AM335X-GP rev 2.1 Model: Bosch AM335x Guardian I2C: ready DRAM: 256 MiB NAND: 512 MiB MMC: OMAP SD/MMC: 0 Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Signed-off-by: Martyn Welch <martyn.welch@collabora.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Felix Brack <fb@ltec.ch>
2019-02-01am335x, shc: adapt shc board to DMHeiko Schocher
port the am335x based shc board to DM, to get rid of DW warnings when compiling U-Boot. - remove uneccessary board code - adapt defconfigs - remove unneeded defconfigs configs/am335x_shc_prompt_defconfig configs/am335x_shc_sdboot_prompt_defconfig Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01ARM: dts: am335x-shc: add u-boot specific dtsiHeiko Schocher
add u-boot specific am335x-shc-u-boot.dtsi file, in which we add u-boot specific adaptions. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01arm: dts: add am335x-shc.dts for shc boardHeiko Schocher
add DTS from linux tree commit "47bfa6d9dc8c060bf56554a465c9031e286d2f80" change for U-Boot: switch to SPDX-license identifier. Signed-off-by: Heiko Schocher <hs@denx.de>
2018-03-05spl: Kconfig: Rename SPL_USBETH_SUPPORT to SPL_USB_ETHER to match with the ↵Faiz Abbas
U-boot CONFIG Rename CONFIG_SPL_USBETH_SUPPORT to CONFIG_SPL_USB_ETHER. This enables users to block text using CONFIG_IS_ENABLED() instead of resorting to #if ladders with SPL and non-SPL cases. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-02-05am335x, shc: kconfig: Fix misspelled choice defaultUlf Magnusson
There is no EMMC symbol in the "enable different boot versions for the shc board" choice. SHC_EMMC was probably intended. No functional changes. Kconfig choices fall back on using the first (visible) symbol in the choice as the default if the default symbol is not visible. Discovered in Kconfiglib (https://github.com/ulfalizer/Kconfiglib), which prints the following warning: warning: the default selection EMMC (undefined) of <choice> (defined at board/bosch/shc/Kconfig:15) is not contained in the choice I've added a corresponding warning to the C tools too, which is currently in linux-next: https://patchwork.kernel.org/patch/9983667/ Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-09am335x, shc: add support for the am335x based bosch shc boardHeiko Schocher
U-Boot SPL 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:40:06) SHC C3-Sample MPU reference clock runs at 6 MHz Setting MPU clock to 594 MHz Enabling Spread Spectrum of 18 permille for MPU Trying to boot from MMC reading u-boot.img reading u-boot.img U-Boot 2016.03-rc3-00019-g6dfb4c2-dirty (Mar 09 2016 - 07:05:35 +0100) Watchdog enabled I2C: ready DRAM: 512 MiB reloc off 1f783000 MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Net: cpsw U-Boot# Signed-off-by: Heiko Schocher <hs@denx.de>
