path: root/board/bmw
2010-09-28bmw: Remove duplicated include of header fileThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2009-07-19Fix boards broken after removal of legacy NAND and DoC supportWolfgang Denk
Commit 2419169f removed support for legacy NAND and disk on chip but missed to update the code for a few boards. This patch fixes the resulting build issues. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-26Initial revisionwdenk
2002-08-14Initial revisionwdenk
2002-08-07Initial revisionwdenk
2002-08-06Initial revisionwdenk
