path: root/board/bmw
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-26Initial revisionwdenk
2002-08-14Initial revisionwdenk
2002-08-07Initial revisionwdenk
2002-08-06Initial revisionwdenk
