It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The current macro is a misnomer since it does not declare a device
directly. Instead, it declares driver_info record which U-Boot uses at
runtime to create a device.
The distinction seems somewhat minor most of the time, but is becomes
quite confusing when we actually want to declare a device, with
of-platdata. We are left trying to distinguish between a device which
isn't actually device, and a device that is (perhaps an 'instance'?)
It seems better to rename this macro to describe what it actually is. The
macros is not widely used, since boards should use devicetree to declare
devices.
Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is
declaring a new driver_info record, not a device.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
Rename this to be consistent with the change from 'platdata'.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
These functions relate to memory init so move them into the init
header.
A number of board function belong in init.h with the others. Move them.
Move env_get() over to the new header file.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Enable DM_SPI for atmel SPI driver on gurnard board.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
Rather than relying on common.h to provide this include, which is going
away at some point, include it explicitly in each file.
add at least icache support for at91 based boards.
This speeds up NOR flash access on an at91sam9g15
based board from 15.2 seconds reading 8 MiB from
a SPI NOR flash to 5.7 seconds.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
This board is based on Snapper 9G45 which has an Atmel AT91SAM9G45 chip and
128MB of SDRAM. It includes a small LCD, 2xUSB host, SD card, Ethernet and
two UARTs.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
[apply CONFIG_BOOTDELAY transition]
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Due to introducing the new peripheral clock handle functions,
use these functions to reduce duplicated code.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Heiko Schocher <hs@denx.de>
[Rebased on current master, fixup for at91rm9200ek]
The board select menu in arch/arm/Kconfig is still big.
To slim down it, this commit moves AT91 boards to
arch/arm/mach-at91/Kconfig.
Also, consolidate "config SYS_SOC" in each board Kconfig.
The Kconfig files under board/ directory were modified with the
following command:
find board -name Kconfig | xargs sed -i -e '
/config SYS_SOC/ {
N
/default "at91"/ {
N
d
Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
The old maintainer has left, so take this over.
Convert this at91sam9260-based board to use driver model. This should serve
as an example for other similar boards. Serial and GPIO are supported so
far.
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
add common phy reset code into a common function.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Jens Scharsig <esw@bus-elektronik.de>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Stelian Pop <stelian@popies.net>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Eric Benard <eric@eukrea.com>
Cc: Markus Hubig <mhubig@imko.de>
Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Tested-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20
single board computer modules. Includes NAND flash and Ethernet
support.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
