path: root/board/bluewater/gurnard/Makefile
2016-06-12arm: at91: Add support for gurnardAndre Renaud
This board is based on Snapper 9G45 which has an Atmel AT91SAM9G45 chip and 128MB of SDRAM. It includes a small LCD, 2xUSB host, SD card, Ethernet and two UARTs. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [apply CONFIG_BOOTDELAY transition] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
