path: root/board/bluegiga
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Include asm/setup.h explictlySimon Glass
Include this header where needed so we do not need to rely on common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-10ARM: mxs: Receive r0 and r1 passed from BootROMMarek Vasut
Make sure value in register r0 and r1 is preserved and passed to the board_init_ll() and mxs_common_spl_init() where it can be processed further. The value in r0 can be configured during the BootStream generation to arbitary value, r1 contains pointer to return value from CALL'd function. This patch also clears the value in r0 before returning to BootROM to make sure the BootROM is not confused by this value. Finally, this patch cleans up some comments in the start.S file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28mxs: mmc: Allow overriding default card detect implementationMarek Vasut
Some MXS based boards do not implement the card-detect signal. Allow user to specify alternate card-detect implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: clock: Use 'mxs' prefix for methodsOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Rename 'mx28_dram_init' to 'mxs_dram_init'Otavio Salvador
The DRAM initialization, after SPL has complete, is exactly the same for all mxs SoCs so we should name it accordinly. The following boards has been changed: * apx4devkit * m28evk * mx28evk * sc_sps_1 Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
2012-09-01mxs: Convert sys_proto.h prefixes to 'mxs'Otavio Salvador
The sys_proto.h functions (except the boot modes) are compatible with i.MX233 and i.MX28 so we use 'mxs' prefix for its methods. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01MX28: Move the u-boot.bd info CPUDIR/SOCDIRMarek Vasut
This gets us rid of duplication of the same file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Reowork SPL to use 'mxs' prefix for methodsOtavio Salvador
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-09-01Add support for Bluegiga APX4 Development KitVeli-Pekka Peltola
This adds support for Bluegiga APX4 Development Kit. It is built around Freescale i.MX28. Currently supported features are: ethernet, I2C, MMC, RTC and USB. APX4 has only one ethernet port. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Stefano Babic <sbabic@denx.de>
