path: root/board/blackvme
2011-04-08Blackfin: bf537-pnav/blackstamp/blackvme: drop empty config.mk filesMike Frysinger
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: blackvme: new board portWojtek Skulski
The board includes: * ADSP-BF561 rev. 0.5 * 32-bit SDRAM (2 * MT48LC16M16A2TG or MT48LC32M16A2TG) * Gigabit Ether AX88180 (ASIX) + 88E1111 rev. B2 (Marvell) * SPI boot flash on PF2 (M25P64 8MB, or M25P128 16 MB) * FPGA boot flash on PF3 (M25P64 8MB, or M25P128 16 MB) * Spartan6-LX150 (memory-mapped; both PPIs also connected) * See http://www.skutek.com/ Signed-off-by: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
