path: root/board/blackvme/Makefile
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2013-11-01blackfin: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2010-10-02Blackfin: blackvme: new board portWojtek Skulski
The board includes: * ADSP-BF561 rev. 0.5 * 32-bit SDRAM (2 * MT48LC16M16A2TG or MT48LC32M16A2TG) * Gigabit Ether AX88180 (ASIX) + 88E1111 rev. B2 (Marvell) * SPI boot flash on PF2 (M25P64 8MB, or M25P128 16 MB) * FPGA boot flash on PF3 (M25P64 8MB, or M25P128 16 MB) * Spartan6-LX150 (memory-mapped; both PPIs also connected) * See http://www.skutek.com/ Signed-off-by: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
