path: root/board/bf561-ezkit/bf561-ezkit.c
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: drop dead/wrong debug code in initdram()Mike Frysinger
The DEBUG code in initdram() is quite old and was never really useful, so just drop it altogether. Common Blackfin debug code does a better job. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: bf561-ezkit: drop redundant codeMike Frysinger
Common Blackfin code already announces CPU information. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: bf561-ezkit: drop pointless USB codeMike Frysinger
The USB/LAN register settings are not actually used/needed in order to drive things from U-Boot, so drop the code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-20[Blackfin][PATCH] Add BF561 EZKIT board supportAubrey Li
