path: root/board/bf537-stamp
2009-01-07bf537-stamp/nand: fix board_nand_init prototypeMike Frysinger
The board_nand_init() function should return an int, not void. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: linker scripts: force start.o and set initcode boundariesMike Frysinger
Make sure that the start.o object is always the first object in our linker script regardless of configuration settings, and add some linker symbols so the ldr utility can properly locate the initcode when generating a LDR. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of Blackfin EMAC Ethernet controller to board_eth_init()Ben Warren
Added board_eth_init() function to bf537-stamp board. Removed initialization for the Blackin EMAC driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: BF537-stamp: cleanup spi flash driverMike Frysinger
This punts the old spi flash driver for a new/generalized one until the common one can be integrated. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-25net/Blackfin: move on-chip MAC driver into drivers/net/Mike Frysinger
The Blackfin on-chip MAC driver was being managed in the BF537-STAMP board directory, but it is not board specific, so relocate it to the drivers dir so that other Blackfin ports can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: BF537-stamp: drop board-specific flash driver for CFIMike Frysinger
The parallel flash on the BF537-STAMP is CFI compliant, so there is no need for the board specific driver at all. Just use the common CFI driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: move bootldr command to common codeMike Frysinger
This moves the Blackfin-common bootldr command out of the BF537-STAMP specific board directory and into the common directory so that all Blackfin boards may utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2008-01-16bf537-stamp: remove already defined is_zero_ether_addr and ↵Jean-Christophe PLAGNIOL-VILLARD
is_multicast_ether_addr and move is_valid_ether_addr board file Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-19[Blackfin][PATCH] minor cleanupAubrey Li
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
