Previously, a specific file or directory could be compiled with custom
CFLAGS by adding a Makefile variable such as:
CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c>
or
CFLAGS_lib = <custom flags for lib directory>
This method breaks down once multiple files or directories share the
same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in
both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>.
This change allows finer grained control which we need once we move
lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this
change all lib/ directories would share the same custom CFLAGS.
While the initdram() function makes sense on some arches, it doesn't for
Blackfin systems as it's always implemented the same way.
The BF537-STAMP Blackfin board had a driver for working with NAND devices
that are simply memory mapped. Since there is nothing Blackfin specific
about this, generalize the driver a bit so that everyone can leverage it.
Building the compression code in lib_generic/ with -O2 rather than -Os
gives a nice speed boost without too much code size increase.
All the Blackfin linker scripts were duplicated across the board dirs with
no difference save from the semi-often used ENV_IS_EMBEDDED option. So
unify all of them in the lib_blackfin/ dir and for the few boards that
need to embedded the environment directly, add a LDS_BOARD_TEXT define for
them to customize via their board config file. This is much simpler than
forcing them to duplicate the rest of the linker script.
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Use the common net eth functions to setup the env/global data with the MAC
address, and properly handle the case where CONFIG_SYS_NO_FLASH is defined.
The Boot ROM uses EVT1 as the entry point so set that rather than having
to use a tiny jump block in the default EVT1 location.
Move the default SPI CS that we boot from into common code so that it can
be used in other SPI drivers and environment settings.
Import the is_valid_ether_addr() function from the Linux kernel.
The BF538/BF539 use CS2 for booting off of rather than CS1 like newer
Blackfin parts.
No functional changes here; just cleanup code style a bit.
The DEBUG code in initdram() is quite old and was never really useful, so
just drop it altogether. Common Blackfin debug code does a better job.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
The board_nand_init() function should return an int, not void.
Many of the Blackfin board linker scripts are preprocessed, so make sure we
output the linker script into the build tree rather than the source tree.
Make sure all .text sections get pulled in and the entry point is properly
referenced so they don't get discarded when linking with --gc-sections.
In order to boot an LDR out of parallel flash, the ldr utility needs a few
flags to tell it to generate the right header.
Make sure that the start.o object is always the first object in our linker
script regardless of configuration settings, and add some linker symbols
so the ldr utility can properly locate the initcode when generating a LDR.
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
Added board_eth_init() function to bf537-stamp board.
Removed initialization for the Blackin EMAC driver from net/eth.c
- Fixing leading white spaces
- Fixing indentation where 4 spaces are used instead of tab
- Removing C++ comments (//), wherever I introduced them
Signed-off-by: William Juul <william.juul@tandberg.com>
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
All of the duplicated code for Blackfin processors and boot modes have been
unified. After all, the core is the same for all processors, just the
peripheral set differs (which gets handled in the drivers).
This punts the old spi flash driver for a new/generalized one until the
common one can be integrated.
The Blackfin on-chip MAC driver was being managed in the BF537-STAMP board
directory, but it is not board specific, so relocate it to the drivers dir
so that other Blackfin ports can utilize it.
The parallel flash on the BF537-STAMP is CFI compliant, so there is no need
for the board specific driver at all. Just use the common CFI driver.
Stop tying things to the processor that should be tied to other defines and
change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build
system to select the -mcpu option.
This moves the Blackfin-common bootldr command out of the BF537-STAMP
specific board directory and into the common directory so that all Blackfin
boards may utilize it.
is_multicast_ether_addr
and move is_valid_ether_addr board file
