path: root/board/bf537-stamp
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: BF537-stamp: cleanup spi flash driverMike Frysinger
This punts the old spi flash driver for a new/generalized one until the common one can be integrated. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-25net/Blackfin: move on-chip MAC driver into drivers/net/Mike Frysinger
The Blackfin on-chip MAC driver was being managed in the BF537-STAMP board directory, but it is not board specific, so relocate it to the drivers dir so that other Blackfin ports can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: BF537-stamp: drop board-specific flash driver for CFIMike Frysinger
The parallel flash on the BF537-STAMP is CFI compliant, so there is no need for the board specific driver at all. Just use the common CFI driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: move bootldr command to common codeMike Frysinger
This moves the Blackfin-common bootldr command out of the BF537-STAMP specific board directory and into the common directory so that all Blackfin boards may utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2008-01-16bf537-stamp: remove already defined is_zero_ether_addr and ↵Jean-Christophe PLAGNIOL-VILLARD
is_multicast_ether_addr and move is_valid_ether_addr board file Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-19[Blackfin][PATCH] minor cleanupAubrey Li
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
