path: root/board/bf537-stamp/post-memory.c
2011-09-29Blackfin: bf537-stamp: convert to gpio post hotkeyMike Frysinger
No need for our custom implementations now that common code supports the generic gpio layer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf537-stamp: post: update old MMR style macrosMike Frysinger
The old MMR defines are being scrubbed, so convert the driver to use the new standard helper macros. For the GPIO MMR usage, convert to the new GPIO framework. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: bf537-stamp: move CONFIG_POST handling to COBJS-$(...)Mike Frysinger
2009-01-28Blackfin: tighten up post memory coding styleMike Frysinger
No functional changes here; just cleanup code style a bit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
