path: root/board/bf537-stamp/bf537-stamp.c
2012-02-12Blackfin: bf537-stamp: drop board reset workaroundMike Frysinger
The bf537-stamp shouldn't need this SPI flash workaround. It was added by accident a long time ago through a convoluted series of steps which originated from a customer board (not the bf537-stamp). So drop it to keep people from incorrectly adding it to their own boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: bf537-stamp: use common spi boot workaround codeMike Frysinger
The common gpio code provides a function for handling the spi boot workaround logic, so switch over to that rather than bang on the gpio MMRs directly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf537-stamp: split CF/IDE code out into dedicated cf-ide.cMike Frysinger
2009-03-24Blackfin: bf537-stamp: split post code out into dedicated post.cMike Frysinger
2009-03-24Blackfin: bf537-stamp: rewrite MAC-in-flash handlingMike Frysinger
Use the common net eth functions to setup the env/global data with the MAC address, and properly handle the case where CONFIG_SYS_NO_FLASH is defined. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-01Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2009-01-28Move is_valid_ether_addr() to include/net.hMike Frysinger
Import the is_valid_ether_addr() function from the Linux kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Blackfin: drop dead/wrong debug code in initdram()Mike Frysinger
The DEBUG code in initdram() is quite old and was never really useful, so just drop it altogether. Common Blackfin debug code does a better job. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of Blackfin EMAC Ethernet controller to board_eth_init()Ben Warren
Added board_eth_init() function to bf537-stamp board. Removed initialization for the Blackin EMAC driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: move bootldr command to common codeMike Frysinger
This moves the Blackfin-common bootldr command out of the BF537-STAMP specific board directory and into the common directory so that all Blackfin boards may utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-01-16bf537-stamp: remove already defined is_zero_ether_addr and ↵Jean-Christophe PLAGNIOL-VILLARD
is_multicast_ether_addr and move is_valid_ether_addr board file Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
