path: root/board/bf537-srv1
2014-05-12blackfin: replace bfin_gen_rand_mac() with eth_random_addr()Masahiro Yamada
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet address. This makes the build non-deterministic. In the first place, it should not be implemented as a Bfin-specific function. Use eth_random_addr() instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2013-11-01blackfin: convert makefiles to Kbuild styleMasahiro Yamada
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: bf537-srv1: new board portMike Frysinger
