We don't want/use this value for Blackfin boards, so punt it and have the
common code error out when people try to use it.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
In case there is no frame buffer driver present in Linux to hand over the
PPI LCD DMA upon boot, the DMA initiated by u-boot to display the splash
screen runs unattended. Therefore always stop the video driver in u-boot
before starting Linux. If people don't want this behavior, then they can
simply stub out the video_stop() function in their board video driver.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Much of the local bf533-stamp.h header is unused, and the few bits that
are are only needed in one file. So move the few used bits out and punt
all the rest.
Rather than bang MMRs directly, use the new portmux framework to handle
the details.
Now that we have a unified gpio layer, the different status led
implementations can be switched to the common gpio led driver.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Previously, a specific file or directory could be compiled with custom
CFLAGS by adding a Makefile variable such as:
CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c>
or
CFLAGS_lib = <custom flags for lib directory>
This method breaks down once multiple files or directories share the
same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in
both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>.
This change allows finer grained control which we need once we move
lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this
change all lib/ directories would share the same custom CFLAGS.
Give the CF/IDE code its own file to keep things cleanly separated. While
we're here, clean up the code to use common functions.
While the initdram() function makes sense on some arches, it doesn't for
Blackfin systems as it's always implemented the same way.
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
All in-tree boards that use this controller have CONFIG_NET_MULTI
added
Also:
- changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111
- cleaned up line lengths
- modified all boards that override weak function in this driver
- modified all eeprom standalone apps to work with new driver
- updated blackfin standalone EEPROM app after testing
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
Building the compression code in lib_generic/ with -O2 rather than -Os
gives a nice speed boost without too much code size increase.
All the Blackfin linker scripts were duplicated across the board dirs with
no difference save from the semi-often used ENV_IS_EMBEDDED option. So
unify all of them in the lib_blackfin/ dir and for the few boards that
need to embedded the environment directly, add a LDS_BOARD_TEXT define for
them to customize via their board config file. This is much simpler than
forcing them to duplicate the rest of the linker script.
Now that the common SPI flash code supports all the flashes, we can stop
using the old driver.
Again, don't clobber pins that we aren't actually using, and use the common
LED framework rather than our own hob-job-but-not-really-working.
The Boot ROM uses EVT1 as the entry point so set that rather than having
to use a tiny jump block in the default EVT1 location.
The old swap function tended to clobber unrelated pins and screw up masks.
Rewrite the thing from scratch so it only uses the resources it needs.
This video driver used to live in the Blackfin cpu directory, but it was
lost during the unification process. This brings it back.
The DEBUG code in initdram() is quite old and was never really useful, so
just drop it altogether. Common Blackfin debug code does a better job.
Many of the Blackfin board linker scripts are preprocessed, so make sure we
output the linker script into the build tree rather than the source tree.
Make sure all .text sections get pulled in and the entry point is properly
referenced so they don't get discarded when linking with --gc-sections.
In order to boot an LDR out of parallel flash, the ldr utility needs a few
flags to tell it to generate the right header.
Make sure that the start.o object is always the first object in our linker
script regardless of configuration settings, and add some linker symbols
so the ldr utility can properly locate the initcode when generating a LDR.
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
All of the duplicated code for Blackfin processors and boot modes have been
unified. After all, the core is the same for all processors, just the
peripheral set differs (which gets handled in the drivers).
This punts the old spi flash driver for a new/generalized one until the
common one can be integrated.
Stop tying things to the processor that should be tied to other defines and
change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build
system to select the -mcpu option.
support
