path: root/board/bf533-stamp
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-11Blackfin: shutdown video DMA when booting LinuxMichael Hennerich
In case there is no frame buffer driver present in Linux to hand over the PPI LCD DMA upon boot, the DMA initiated by u-boot to display the splash screen runs unattended. Therefore always stop the video driver in u-boot before starting Linux. If people don't want this behavior, then they can simply stub out the video_stop() function in their board video driver. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf533-stamp: scrub unused codeMike Frysinger
Much of the local bf533-stamp.h header is unused, and the few bits that are are only needed in one file. So move the few used bits out and punt all the rest. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf533-stamp: convert eth/flash swap logic to gpio frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: switch to common GPIO LED driverMike Frysinger
Now that we have a unified gpio layer, the different status led implementations can be switched to the common gpio led driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: bf533-stamp: split and cleanup CF/IDE codeMike Frysinger
Give the CF/IDE code its own file to keep things cleanly separated. While we're here, clean up the code to use common functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-15Blackfin: enable -O2 in lib_generic/ for ADI/Bluetechnix boardsMike Frysinger
Building the compression code in lib_generic/ with -O2 rather than -Os gives a nice speed boost without too much code size increase. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf533-stamp: drop old spi flash driverMike Frysinger
Now that the common SPI flash code supports all the flashes, we can stop using the old driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf533-stamp: rewrite startup LED notificationsMike Frysinger
Again, don't clobber pins that we aren't actually using, and use the common LED framework rather than our own hob-job-but-not-really-working. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: kill off LDR jump blockMike Frysinger
The Boot ROM uses EVT1 as the entry point so set that rather than having to use a tiny jump block in the default EVT1 location. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: convert old boards to use COBJS-y Makefile styleMike Frysinger
2009-01-28Blackfin: bf533-stamp: rewrite resource swap logicMike Frysinger
The old swap function tended to clobber unrelated pins and screw up masks. Rewrite the thing from scratch so it only uses the resources it needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: punt unused BF533-STAMP definitionsMike Frysinger
2009-01-28Blackfin: resurrect BF533-STAMP video splash driverMike Frysinger
This video driver used to live in the Blackfin cpu directory, but it was lost during the unification process. This brings it back. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: drop dead/wrong debug code in initdram()Mike Frysinger
The DEBUG code in initdram() is quite old and was never really useful, so just drop it altogether. Common Blackfin debug code does a better job. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: linker scripts: force start.o and set initcode boundariesMike Frysinger
Make sure that the start.o object is always the first object in our linker script regardless of configuration settings, and add some linker symbols so the ldr utility can properly locate the initcode when generating a LDR. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: punt old unused mem_init.h headerMike Frysinger
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: BF537-stamp: cleanup spi flash driverMike Frysinger
This punts the old spi flash driver for a new/generalized one until the common one can be integrated. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
