path: root/board/bf533-stamp
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: BF537-stamp: cleanup spi flash driverMike Frysinger
This punts the old spi flash driver for a new/generalized one until the common one can be integrated. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
