path: root/board/bf533-ezkit
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: linker scripts: force start.o and set initcode boundariesMike Frysinger
Make sure that the start.o object is always the first object in our linker script regardless of configuration settings, and add some linker symbols so the ldr utility can properly locate the initcode when generating a LDR. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-04-05[Blackfin][PATCH]: fix flash unaligned copy issueAubrey Li
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
