path: root/board/bf533-ezkit
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: enable -O2 in lib_generic/ for ADI/Bluetechnix boardsMike Frysinger
Building the compression code in lib_generic/ with -O2 rather than -Os gives a nice speed boost without too much code size increase. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: kill off LDR jump blockMike Frysinger
The Boot ROM uses EVT1 as the entry point so set that rather than having to use a tiny jump block in the default EVT1 location. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: fixup misc warnings such as printf's and missing castsMike Frysinger
2009-01-28Blackfin: convert old boards to use COBJS-y Makefile styleMike Frysinger
2009-01-28Blackfin: drop dead/wrong debug code in initdram()Mike Frysinger
The DEBUG code in initdram() is quite old and was never really useful, so just drop it altogether. Common Blackfin debug code does a better job. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: bf533-ezkit: shuffle flash defines a littleMike Frysinger
Some of the flash defines weren't in the correct location and caused build problems in some configurations, so let's move types and defines to better local locations. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-23Blackfin: linker scripts: force start.o and set initcode boundariesMike Frysinger
Make sure that the start.o object is always the first object in our linker script regardless of configuration settings, and add some linker symbols so the ldr utility can properly locate the initcode when generating a LDR. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04punt Blackfin VDSP headers and import sanitized/auto-generated onesMike Frysinger
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-04-05[Blackfin][PATCH] Fix copyright and update licenseAubrey Li
2007-04-05[Blackfin][PATCH]: fix flash unaligned copy issueAubrey Li
2007-03-12[Blackfin][PATCH] Fix BUILD_DIR option of MAKEALL building issueAubrey Li
2007-03-12[Blackfin][PATCH] code cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
