path: root/board/bct-brettl2
2011-06-03Blackfin: boards: build zlib dir with -O2Mike Frysinger
Now that the zlib code has been relocated to a dedicated subdir, make sure we still build it with -O2 for boards that want speed over size. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-02Blackfin: bct-brettl2: new board portPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
