path: root/board/bc3450
2015-03-17powerpc: mpc5xxx: remove BC3450 board supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-07-22BC3450 board: Remove unused CONFIG_SYS_CPU definitionWolfgang Denk
This fixes: cmd_bc3450.c:55:0: warning: "CONFIG_SYS_CPU" redefined [enabled by default] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2012-07-22BC3450 board: change debug code to using debug()Wolfgang Denk
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-11Fix some more print() format errors.Wolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc5xxx linker scripts (2 of 3)Grant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-11-01- Add MPC5XXX register definition MPC5XXX_WU_GPIO_DATA_I and change theBartlomiej Sieka
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with MPC5XXX_WU_GPIO_DATA_O for affected boards. - Add defintions for some MPC5XXX GPIO pins.
2006-05-03Coding Style cleanupWolfgang Denk
2006-04-21Add support for BC3450 boarddzu@denx.de
Signed-off-by: dzu@denx.de <dzu@denx.de>
