path: root/board/bc3450/cmd_bc3450.c
2012-07-22BC3450 board: Remove unused CONFIG_SYS_CPU definitionWolfgang Denk
This fixes: cmd_bc3450.c:55:0: warning: "CONFIG_SYS_CPU" redefined [enabled by default] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2012-07-22BC3450 board: change debug code to using debug()Wolfgang Denk
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-07-11Fix some more print() format errors.Wolfgang Denk
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-05-03Coding Style cleanupWolfgang Denk
2006-04-21Add support for BC3450 boarddzu@denx.de
Signed-off-by: dzu@denx.de <dzu@denx.de>
