path: root/board/barco
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-10Fix some more print() format errors.Wolfgang Denk
2007-07-04Remove obsolete mpc824x linker scripts (1 of 4)Grant Likely
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-09-25Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) boardWolfgang Denk
Patch by Marc Leeman, 04 Mar 2005
