path: root/board/bachmann
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-18imx6: drop duplicated bss memset and board_init_r() callAnatolij Gustschin
bss section is cleared in crt0.S. board_init_r() is also entered from crt0 code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <lukma@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-12ot1200: Fix unused variable warningTom Rini
The variable pwm_pad is never referenced, drop. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2015-11-12ot1200: Remove empty reset_cpu()Fabio Estevam
There is really no need to provide an empty reset_cpu() implementation, so just remove it. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-09-13ot1200: Fix the error handling in board_eth_init()Fabio Estevam
We should not return 0 on failure, so return a negative error code instead. Also centralize the error path so that is easier to follow. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-06-08ot1200: setup i2c bus 1 in setup_iomux_i2c()Christian Gmeiner
On this bus there is a EEPROM containing EDID and ddr3 calibration information. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-06-08ot1200: setup i2c bus in board_early_init_f(..)Christian Gmeiner
Make it possible to use the i2c bus in SPL. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-01-22ot1200: add basic SPL supportChristian Gmeiner
Currently we only support the Micron MT41K128M16JT-125 ddr3 chip. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-01-22ot1200: enable spi clock directly in ccgr_init(..)Christian Gmeiner
2015-01-22ot1200: move ccgr and gpr init to c functionsChristian Gmeiner
We need this way for SPL boot. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-01-22ot1200: make use of imx_ddr_size(..)Christian Gmeiner
To support different ddr3 memory sizes we should start using imx_ddr_size(..) instead of the define PHYS_SDRAM_SIZE. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-11-24ot1200: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13ot1200: fix card detect for usdhc4Christian Gmeiner
Today I got the final board and found out that a different connector is used as the one on my development board. The new connector has swaped pins for cd and wp. This change is tested on a production ready board. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-10-30ot1200: rework card detect for eMMCChristian Gmeiner
2014-10-30ot1200: add support for usdhc4Christian Gmeiner
On the 'mr' variant switching to 'mmc dev 1' will result in "MMC: no card present". Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-10-30ot1200: add feature padsChristian Gmeiner
The older 'mr' variant and the generic variant of the OT1200 differ in some places. As the name suggests the generic variant supports more boot devices. In order to be compatible with the 'mr' variant we define some 'feature' GPIOs. On the 'mr' variant this pads are not connected so we define their state with the help of the internal pullups. On the generic variant this GPIOs are connected and represent the state of the hardware. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23ot1200: add sata supportChristian Gmeiner
One of the possible boot devices can be sata. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2014-10-23ot1200: fix sf detectionChristian Gmeiner
Commit 155fa9af95ac5be857a7327e7a968a296e60d4c8 changed the way to define a GPIO line, which can be used to force CS high across multiple transactions. In order to fix sf detection change board code to make use of board_spi_cs_gpio(..). Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-10-21ot1200: remove superfluous "string" tagChristian Gmeiner
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-06imx6: add Bachmann OT1200 boardChristian Gmeiner
This patch adds support for the OT1200 series of devices. Following components are used in u-boot: + ethernet + i2c + emmc + gpio For more details see README. Changes v1 > v2 - make use of enable_cspi_clock(..) - fix usage of OUTPUT_40OHM define - added README Changes v2 > v3 - improve spelling in README - added own copy of mx6q_4x_mt41j128.cfg Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
