path: root/board/avionic-design
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: Tegra30 pinmux cleanupStephen Warren
This renames all the pinmux pins, drive groups, and functions so they have a prefix which matches the type name. These lists are also auto- generated using scripts that were also used to generate the kernel pinctrl drivers. This ensures that the lists are consistent between the two. The entries in tegra30_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. This introduces a few changes to pin/group/function naming and the set of available functions for each pin. The new values now exactly match the TRM; the chip documentation. I adjusted one entry in pinmux-config-cardhu.h due to this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: pinmux naming consistency fixesStephen Warren
Clean up the naming of pinmux-related objects: * Refer to drive groups rather than pad groups to match the Linux kernel. * Ensure all pinmux API types are prefixed with pmux_, values (defines) are prefixed with PMUX_, and functions prefixed with pinmux_. * Modify a few type names to make their content clearer. * Minimal changes to SoC-specific .h/.c files are made so the code still compiles. A separate per-SoC change will be made immediately following, in order to keep individual patch size down. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-01-24board: tec-ng: Do not make directories in a board MakefileMasahiro Yamada
Commit e5c5301f refactored the build system not to make directories in board makefiles. But commit 8f380381 create directories again in board/avionic-design/tec-ng/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Alban Bedel <alban.bedel@avionic-design.de>
2013-12-18ARM: tegra: Add the Tamonten™ NG Evaluation Carrier boardAlban Bedel
Add support for the new Tamonten™ NG platform from Avionic Design. Currently only I2C, MMC, USB and ethernet have been tested. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-04-15Tegra: All Tamonten-derived boards use onboard NANDThierry Reding
Move the nand-controller node to the tegra20-tamonten.dtsi so that it can be shared between all derived boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: MMC: Add DT support to MMC driver for all T20 boardsTom Warren
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional. Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT filesTom Warren
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux). Signed-off-by: Tom Warren <twarren@nvidia.com> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: tamonten: Add common tamonten.dtsi file from linuxTom Warren
Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Change /include/ to #include for C preprocessorTom Warren
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS. This allows the use of '#include "xyz"' in the dts/dtsi file which helps the C preprocessor find common dtsi include files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-01-17tegra: fdt: sort dts filesAllen Martin
Sort nodes in dts files according the the following rules: 1) Any nodes that already exist in any /include/d file, in the order they appear in the /include/d file. 2) Any nodes with a reg property, in order of their address. 3) Any nodes without a reg property, alphabetically by node name. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-17tegra: fdt: remove clocks nodesAllen Martin
These nodes are unused. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: Enable LCD on TECThierry Reding
The TEC ships with a 7" LCD panel that provides a resolution of 800x480 pixels. Add a corresponding panel description to the device tree and enable LCD support in the configuration. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: Enable LCD on Medcom-WideThierry Reding
The Medcom-Wide has a 15" LCD panel with a resolution of 1366x768 pixels. Add a corresponding panel description to the device tree and enable LCD support in the configuration. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29tegra: move common features to a common makefileMarc Dietrich
For Non-Nvidia boards to include newly added features (like emc clock scaling) it would be necessary to add each feature to their own board Makefile. This is because currently the top Makefile automaticly includes these features only for Nvidia boards. This patch adds a simple Makefile include so all new features become available for non-Nvidia board vendors. Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Warren <twarren@nvidia.com> Cc: Thierry Reding <thierry.reding@avionic-design.de> Cc: Lucas Stach <dev@lynxeye.de> Signed-off-by: Marc Dietrich <marvin24@gmx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: rework UART GPIO handlingLucas Stach
Rename board provided gpio_config_uart() to gpio_early_init_uart() as it does the same thing as the equally called function provided by the uart-switch code. This allows to simply call this function in early board init whether or not we are building with CONFIG_UART_SWITCH defined. Also provide a weak symbol for this function, to avoid the need to provide this function for boards that don't need any fixup. This patch supersedes the earlier posted "tegra: convert gpio_config_uart to weak symbol". Build tested with MAKEALL -s tegra20 Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: Rename Medcom to Medcom-WideThierry Reding
Medcom is the marketing name for an older, PXA-based version of the same device. In order to avoid confusion, rename the Tegra-based version to the new marketing name. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: Update Avionic Design vendor prefixThierry Reding
The official vendor prefix for Avionic Design is now "ad". Update the board DTS files accordingly. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07tegra: Enable NAND on TECThierry Reding
This commit enables NAND support on the Tamonten Evaluation Carrier and adds the corresponding device tree nodes. Furthermore, the U-Boot environment can now be stored in NAND. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: make board mkdir commands unconditionalAllen Martin
Change the mkdir commands for the object directories to be unconditional. This fixes an issue when building for SPL where SRCTREE and OBJTREE are the same, but $(obj) is under SPLTREE. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: fix leftover CONFIG_TEGRA2_MMC & _SPI build switchesTom Warren
Missed some boards after my tegra2_mmc.* -> tegra_mmc.* change, and one instance of CONFIG_TEGRA2_SPI. MAKEALL -s tegra2 AOK, Seaboard MMC AOK. Didn't test Tamonten, Paz00 or TrimSlice, as I have none here. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-09tegra: Add Tamonten Evaluation Carrier supportThierry Reding
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten processor board. More information is available here: http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: Use SD write-protect GPIO on TamontenThierry Reding
GPIO PI6 can be used to obtain the write-protect status of an SD card inserted into the SD slot. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: Implement gpio_early_init() on TamontenThierry Reding
The PI4 GPIO is used on Tamonten to reset carrier board peripherals. Power sequencing hardware on the carrier pulls the reset low before powering up the Tegra, and the CPU is supposed to signal readiness, and therefore bring peripherals out of reset by pulling PI4 high. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: plutux: Add device tree supportThierry Reding
Device tree support is required for working USB host support, which in turn enables ethernet support. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: medcom: Add device tree supportThierry Reding
2012-07-09tegra: Rework Tamonten supportThierry Reding
This commit uses the common Tegra board implementation instead of duplicating a lot of the code. In addition, the Plutux and Medcom specific board files can be removed as the MMC/SD setup is common among all Tamonten-based boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-02-12tegra: Use funcmux for MMC on tamontenSimon Glass
Use the new funcmux_select() feature to set up the MMC pin mux. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Move boards over to use arch-level board UART functionSimon Glass
Now that we can set up the UART in common tegra code, make the boards use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Medcom support.Thierry Reding
The Medcom is a 16:9 15" terminal that is used for patient infotainment in hospitals. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add common Avionic Design Tamonten support.Thierry Reding
Tamonten is an NVIDIA Tegra2-based SO-DIMM processor module that is derived from the Harmony reference design. Changes in v3: * Remove unused gpio_config_uart(). * Remove call to tegra2_start(). * Use new tegra2_mmc_init(). Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
