path: root/board/avionic-design/common
2012-02-12tegra: Use funcmux for MMC on tamontenSimon Glass
Use the new funcmux_select() feature to set up the MMC pin mux. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Move boards over to use arch-level board UART functionSimon Glass
Now that we can set up the UART in common tegra code, make the boards use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add common Avionic Design Tamonten support.Thierry Reding
Tamonten is an NVIDIA Tegra2-based SO-DIMM processor module that is derived from the Harmony reference design. Changes in v3: * Remove unused gpio_config_uart(). * Remove call to tegra2_start(). * Use new tegra2_mmc_init(). Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
