path: root/board/atmel
2018-01-10build: Drop CONFIG_SPL_BUILD guards in some casesTom Rini
Given gcc-6.1 and later we can now safely have strings discarded when the functions are unused. This lets us drop certain cases of not building something so that we don't have the strings brought in when the code was discarded. Simplify the code now by dropping guards we don't need now. Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Wenyou Yang <wenyou.yang@microchip.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-04mtd: nand: Rename nand.h into rawnand.hMasahiro Yamada
This header was renamed to rawnand.h in Linux. The following is the corresponding commit in Linux. commit d4092d76a4a4e57b65910899948a83cc8646c5a5 Author: Boris Brezillon <boris.brezillon@free-electrons.com> Date: Fri Aug 4 17:29:10 2017 +0200 mtd: nand: Rename nand.h into rawnand.h We are planning to share more code between different NAND based devices (SPI NAND, OneNAND and raw NANDs), but before doing that we need to move the existing include/linux/mtd/nand.h file into include/linux/mtd/rawnand.h so we can later create a nand.h header containing all common structure and function prototypes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-29board: atmel: add sama5d2_ptc_ek boardLudovic Desroches
Add the SAMA5D2 PTC EK board and remove the SAMA5D2 PTC ENGI board which was a prototype. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-16Drop CONFIG_HAS_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-29board: at91sam9x5ek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-29board: sama5d4_xplained: Convert to CONFIG_DM_VIDEOWenyou Yang
2017-09-29board: sama5d4ek: Convert to CONFIG_DM_VIDEOWenyou Yang
2017-09-29board: sama5d3xek: Convert to CONFIG_DM_VIDEOWenyou Yang
2017-09-29board: sama5d2_xplained: Convert to CONFIG_DM_VIDEOWenyou Yang
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14board: atmel: Add SAMA5D27 SOM1 EK boardWenyou Yang
The SAMA5D27-SiP (System in Package) integrates the SAMA5D2 with 1Gbit DDR2-SDRAM in a single package. The SAMA5D27 SOM1 embeds a 64Mbit QSPI flash, KSZ8081 Phy and Mac-address EEPROM. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14board: sama5d2_xplained: Make SPL work on spiflashWenyou Yang
Because before switching to a lower clock source, we must switch the clock source first instead of last. So before configuring the PMC_MCKR register, invoke at91_mck_init_down() first. As said in datasheet, the the size of SPL must not exceed the maximum size allowed(64Kbytes). Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14atmel: common: Add function to display via DM_VIDEO's APIWenyou Yang
Add a function to display the company's logo and board information via the API from DM_VIDEO. This function can be shared by other atmel boards, so locate it in board/atmel/common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: sama5d4_xplained: Set mac address from eepromWenyou Yang
Add the code to set the ethernet mac address from eeprom by using the common code from the common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: sama5d2_xplained: Replace code to set mac addressWenyou Yang
Replace the code to set the ethernet mac address with the code from the common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-11board: atmel: Create board/$(VENDOR)/common folderWenyou Yang
Create board/$(VENDOR)/common folder to accommodate the common code shared by other atmel boards, now put the code to set ethernet mac address from eeprom, which uses the i2c eeprom driver. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-04board: at91sam9260ek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
To support driver model and device tree, use the SPI-flash-based AT45xxx DataFlash driver, DataFlash is a kind of SPI flash. Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will be removed in the future. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-04board: at91sam9rlek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
2017-08-04board: at91sam9263ek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
2017-08-04board: at91sam9261ek: Update to support DT and DMWenyou.Yang@microchip.com
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11board: atmel: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-09board: at91sam9263ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9263ek: Clean up codeWenyou Yang
Because the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9263ek: Update for DT and DM supportWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9rlek: Enable early debug UARTWenyou Yang
2017-05-09board: at91sam9rlek: Clean up codeWenyou Yang
Since the introduction of the pinctrl and clk drivers and the device tree files, remove unneeded hard coded related code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9rlek: Update for DT and DM supportWenyou Yang
2017-05-09board: at91sam9260ek/9g20ek: Enable early debug UARTWenyou Yang
2017-05-09board: at91sam9260ek: Clean up codeWenyou Yang
2017-05-09configs: at91sam9260ek/9g20ek: Update for DT and DMWenyou Yang
2017-05-09board: at91sam9m10g45ek: Enable early debug UARTWenyou Yang
2017-05-09board: at91sam9m10g45ek: Clean up codeWenyou Yang
2017-05-09configs: at91sam9m10g45ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9n12ek: Enable early debug UARTWenyou Yang
2017-05-09board: at91sam9n12ek: Clean up codeWenyou Yang
Since the introduction of the pinctrl and clk driver and the device tree files, remove unneeded related code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9n12ek: Update for DT and DM supportWenyou Yang
2017-05-09board: at91sam9x5ek: Enable early debug UARTWenyou Yang
2017-05-09board: at91sam9x5ek: Clean up codeWenyou Yang
Since the introduction of the pinctrl and clock driver and the device tree files, remove unneeded hard coded related code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9x5ek: Update to support DM/DTWenyou Yang
2017-05-09board: sama5d4ek: fix DD2 configurationWenyou Yang
Fix the DDR2 configuration to make SPL work. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-05-09board: sama5d2_xplained: remove unnecessary header filesWenyou Yang
Remove the unnecessary header files. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-05-09board: sama5d2_xplained: remove uart1 initWenyou Yang
Due to the pin configuration and clock enabling is handling by the driver, remove the unneeded hardcode uart1 init during board_early_init_f stage. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-05-09board: sama5d2_xplained: clean up macb init codeWenyou Yang
Because the MACB driver supports the driver model and device tree, the pins configuration and clock enabling are handled by the pinctrl driver and clock driver, remove this hardcoded init code. The USB Ether init code is removed as well. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
