path: root/board/atmel
2010-12-07at91rm9200ek: add configure target for RAM bootAndreas Bießmann
This patch also removes now unnecessary config.mk in board directory and make usage of new features in boards.cfg. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-10-19at91rm9200ek: convert to at91Andreas Bießmann
This patch removes some functionality from at91rm9200ek board but the remaining functionality does now work with newer at91 code and arm-relocation. Currently missing features are: - dataflash booting (due to missing HW for testing) - MMC/SD-Card - first stage bootloader support is completely removed (not needed for NOR) Cause this board was (some days ago) reference for all at91rm9200 based boards this should be a good starting point to convert all remaining at91rm9200 borads to at91 code. Aside from that this is a good base to get some drivers between at91sam/at91rm/avr32 merged. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-09-03avr32: Use uncached() macro to get an address for SDRAM initHaavard Skinnemoen
The paging system which is required to set up caching properties has not yet been initialized when the SDRAM is initialized. So when the map_physmem() function is converted to return the physical address unchanged, the SDRAM initialization will break on some boards. The avr32-specific uncached() macro will return an address which will always cause uncached accessed to be made. Since this happens in the board code, using avr32-specific features should be ok, and will allow the SDRAM initialization to keep working. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-30USB OHCI support for at91sam9g45 SoCSergey Matyukevich
Add USB OHCI support for at91sam9g45ekes/at91sam9m10g45ek boards. Note that according to errata from Atmel, OHCI is not operational on the first revision of at91sam9g45 chip. So this patch enables OHCI support for later revisions. Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com>
2010-06-29avr32: fix linking of atstk100x and favr32 boardsAndreas Bießmann
When building some avr32 boards out of tree (e.g. O=..) the linker script could not be found. This patch references the linker script in source tree. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12update at91sam9263ek board to new SoC accessJens Scharsig
* convert at91sam9263ek board to use c stucture SoC access * change gpio access to at91_gpio syntax Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-07at91sam9261ek.c: fix minor coding style issue.Wolfgang Denk
2009-09-01at91sam9260/afeb9260: Fix SPI initializationAlbin Tonnerre
Commit 7ebafb7ec1a0285af8380623c009576f92583b98 introduced a mistake in the spi init function call for those boards. This patch fixes this. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-06at91sam9260/9263: add back up for the rst(reset controller).Sedji Gaouaou
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was set to 0 after being set to 500 ms for the PHY reset. Do backup the old reset length and restore it after the MACB initialisation. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Stelian Pop <stelian@popies.net>
2009-06-21at91: unify nor boot supportJean-Christophe PLAGNIOL-VILLARD
the lowlevel init sequence is the same so unify it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-21at91sam9263ek: add nor flash supportJean-Christophe PLAGNIOL-VILLARD
this will allow you to store use it for the env and to boot directly U-Boot from Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-15Convert DM9000 driver for CONFIG_NET_MULTIRemy Bohmer
All drivers need to be converted to CONFIG_NET_MULTI. This patch converts the dm9000 driver. Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-04at91rm9200: Reset updateJean-Christophe PLAGNIOL-VILLARD
Update the rm9200 reset sequence to try executing a board-specific reset function and move specific board reset to board. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04Add support for the AT91RM9200EK Board.Ulf Samuelsson
The AT91RM9200-EK Evaluation Board supports the AT91RM9200 ARM9-based 32-bit RISC microcontroller and enables real-time code development and evaluation. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507 with - NOR (cfi driver) - DataFlash - USB OHCI - Net - I2C (hard) Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200dk: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91: rename DATAFLASH_MMC_SELECT to CONFIG_DATAFLASH_MMC_SELECTJean-Christophe PLAGNIOL-VILLARD
2009-03-26Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2009-03-23Merge branch 'mimc200'Haavard Skinnemoen
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22atmel/at91/boards: compile dataflash partition only when dataflash isJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common macb initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common usb host initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common led management to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common spi initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common serial initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-02-23AVR32: Make cacheflush cpu-dependentOlav Morken
The AT32UC3A series of processors doesn't contain any cache, and issuing cache control instructions on those will cause an exception. This commit makes cacheflush.h arch-dependent in preparation for the AT32UC3A-support. Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com> Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com> Signed-off-by: Olav Morken <olavmrk@gmail.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-12-17Merge branch 'fixes' into cleanupsHaavard Skinnemoen
Conflicts: board/atmel/atngw100/atngw100.c board/atmel/atstk1000/atstk1000.c cpu/at32ap/at32ap700x/gpio.c include/asm-avr32/arch-at32ap700x/clk.h include/configs/atngw100.h include/configs/atstk1002.h include/configs/atstk1003.h include/configs/atstk1004.h include/configs/atstk1006.h include/configs/favr-32-ezkit.h include/configs/hammerhead.h include/configs/mimc200.h
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-11-07AT91: Replace AT91_BASE_EMAC by the board specific values.Stelian Pop
AT91_BASE_EMAC is never used outside the board specific files, so replace its usage by the board specific AT91xxx_BASE_EMAC. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-07AT91: Replace (undefined) AT91_ID_US* by the board specific values.Stelian Pop
AT91_ID_US0 / AT91_ID_US1 / AT91_ID_US2 were used but never defined. Since they are never used outside the board specific files, they can be replaced by the board specific AT91xxx_ID_US0 / AT91xxx_ID_US1 / AT91xxx_ID_US2. Bug spotted by Jesus Alvarez <jalvarez@micromint.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12Fix MACH_TYPE for the AT91RM9200DK board.Claudio Scordino
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
